Preach2k
- Jul 19, 2010
- 1,967
- 115
- 63
No MicroSD Card. Can't use the flash drive for my business. Can cause me to get audited by the State.Why not the Note 5?
It's 35 or 40 failures over a very short period of time. What if the probability of battery failure increases over time? Most systems fail more frequently as they wear out.I agree with you but many people are holding onto the 35-40 mantra as justification that their phone is fine.
That assumes all systems are flawed. I thought it was only some of them, in which case the longer you have your phone the less likely it is to have the flaw, statistically speaking.It's 35 or 40 failures over a very short period of time. What if the probability of battery failure increases over time? Most systems fail more frequently as they wear out.
Nothing I said was fear mongering. How a person perceives something in print is their own deal, not mine. Fact - "defective battery". Stating that people need to be responsible is not fear mongering, it just is.Because incorrect fearmongering statements aren't helpful. So far there have been no confirmed cases of batteries catching fire unrelated to charging. Not sure why you felt the need to rely on an incorrect statement to encourage people to return their devices.
Re: the battery *odes. If the separator is not adequate, it can 'wear' over time. Charging and discharging both can affect it, and each can be happening the time the separator fails.Based to some degree on the worry for using the Note 7, we should also perhaps pursue banning fireworks, since exponentially more people (especially under 21) have been injured or worse through the years. Okay, some were when drunk, but still the point is there are things with a bigger chance to hurt or kill that people approach daily as "meh" until something happens.
I keep hearing about issues happening "daily" and piling up by some posters and the media, yet the same garage and Jeep events are recycled as new, but people just now finding out. The terrible event with the 6 year old is new, but even that has respectfully yet to be verified. People even stating it was not charging while being used , but says nothing about that in the article.
All things presumed constant, anode / cathode layer breaches do not normally behave in a ticking bomb manner after initial charges and use. If it is something else beyond that and Samsung is not forthright, kiss the Note 7 (at least) goodbye. Too much attention, especially if/when the three incidents above are verified as legit concerning the Note 7.
The only thing I can think of that would cause a breach after initial charges and use is if a sharp object penetrates the cell and creates anode / cathode contact (a breach). If a layer insulation defect, the energy for an explosive like failure is not normally going to lay dormant for days and weeks of use and then suddenly, kapow!
It would be interesting to see the CPSC's findings, but that would also mean they took the time to visit, audit, interview and test the cells. That means weeks before good. None of this will add up if the issue is so grave as the media points out and this is fast tracked. Point here is I would not be surprised if this takes longer than people might expect. Again, if as dire as perceived.
Re: comparing this situation to banning other dangerous activities. That's absurd. There is no proposed ban on Li-ion batteries, just a recall on this particular batch.
No drama or ill will intended.
I understand batteries from a chemical, physics, production, quality and post failure perspective. All batteries from garage openers to stationary cells for hospital, nuclear and subs.
There is respectfully a lot bogus info being posted in forums and the media and it seems to be a closed loop of the same info then being established as "fact".
None the less, I respect the caution.
The wear typically results in reduced capacitance and heat, but rarely explosions.
The fireworks analogy is in relation to the apparent level of worry of the Note 7 and not a ban.
Absolutely. We'll all have decisions to make once we get the final word on the process, and it sucks whatever the outcome. I don't want to wait for the next version, but if this takes a couple months or so, I will likely wait and hope it is not delayed in 2017 from this mess. That makes me very sad.The main points though regardless are IMO: Caution is good and this situation sucks.
Exactly my point. I love the Note series but it is extremely similar. I've been using it and the only difference I see is no SPen but it is 80-90% the same device.
Absolutely. We'll all have decisions to make once we get the final word on the process, and it sucks whatever the outcome. I don't want to wait for the next version, but if this takes a couple months or so, I will likely wait and hope it is not delayed in 2017 from this mess. That makes me very sad. ??????
The U.S. CPSC points to recent reports of Note 7 phones catching fire “while charging and during normal use,” and so the agency says that owners should power down their phones. The CPSC says that it’s working with Samsung to announce a formal recall of the Note 7
U.S. CPSC urges consumers to stop using Note 7 as it works with Samsung on formal recall - TmoNews
