[RADIOS][VZW] Galaxy Nexus Radios and Installation Guide
It's amazing to me that Samsung let these phones pass quality control when there are numerous obvious problems. But, you'll eventually get a good one...
What do you mean? Have you sent some back for replacement?
Signal strength aside, are you having terrible transitions between 3G and 4G? That is my largest gripe as it basically drops, turns off the radio, then the 3G comes on, but transition from 3G to 4G is seamless. Love this phone and custom ROMs, but the 4G to 3G transitions are driving me a lil crazy. Feel like 4G is unreliable.
yeah, ive been seeing this alot lately
even back on B37, its a bit wonky. i guess my earlier post was a bit premature. trying to stream germany v netherlands, and all i get is low quality, choppy video
really had no issues until recently. maybe i just didnt pay attention as much, or just chalked it up to verizon service. now, after going to b38 with franco, im really unhappy with battery and handoff. trying stable leankernel now.
It's amazing to me that Samsung let these phones pass quality control when there are numerous obvious problems. But, you'll eventually get a good one... not just sammys fault check out my post
Not sure which radio to DL.
4.0.4 radio and bootloader OR
4.0.4 radio?
My gnex is rooted and unlocked. I'm running eclipse ROM. Here is the info on my about phone:
Version
4.0.4
Baseband
1515.09 V.EK05 / 1515.EK02
Build number
Eclipse_toro-userdebug 4.0.4 IMM76D
4.0.4 radio?
Version
4.0.4
Baseband
Build number
The first package, with bootloader.
Reactions: zero neck
Quick question,,,, I installed the radio with the bootloader and everything worked fine. Playing with the gnex the way I do, I accidentally deleted a widget that I couldn't seem to get back. Fortunately I did a backup of my rom just before I installed the radio. I restored the rom and I still have the 1515.09 V.FC04 / 1515.FC05 radio.
My question is: when I restored my rom did it change the Bootloader or did it keep the one I just installed with the radio? Do I need to reflash the radio with the bootloader, or am I good?
Bootloaders/radios are untouched by roms and restores unless that rom specifically says it's changing it.
You're good :).
Thank you again, I don't recall seeing anything during the restore backup that said the bootloader was being changed. I just wanted to make sure I didn't mess it up. Again, thank you!
No problem! FWIW, people flash radios without the corresponding bootloader all the time, so it would likely not cause any serious harm. That being said, it's good practice to keep everything in order :).
Long time lurker chiming in here.
What are your all's experiences with the 3g to 4g and visa versa switiching? I've been trying out all sorts of different radio combinations but it seems I am out of signal quite often. After reading through this thread I think I'm just seeing the delay of when 4g signal is lost and the radio turns off before 3g kicks in.
Anyone found a way to speed this process up? The delay is more than enough to be noticeable, maybe 15-20 seconds when it happens. It happens enough that when I go to google something or send a message I have to stand around staring at my phone waiting for signal. :-(
Bad 4G area, switch to 3g only, that's really all there is to it. I'm at work now and know when I get here to switch to 3g only or the constant hand offs will drive me nuts, not to mention murder a battery.
Man, I was hoping I wouldn't get that response. At least I finally understand what's going on with my two Galaxy Nexuses. I was driving myself crazy trying to figure out why none of the fixes were working for me.
Maybe in a few updates they'll be able to improve the speed in which 4g switches to 3g? I guess people that don't notice this problem are able to sit on 4g or wifi pretty much all the time?
My 3g to 4g hand off is way faster now with the official 404 radios. If you tried the different radios and none work right for ya, I think switching 4g off like 2def suggests is a decent temporary option.
Reporting back again:
I don't think it's an issue of not having enough 4g signal. At work, sure, I barely get 3g at my desk but at home the signal is crazy strong. I don't remember the actual signal strength but it's a steady full bars and I even did a speed test and clocked 32.55Mbps down 14.11Mbps up.
I sat on my couch playing with my phone and it'd go out completely....I'd have no signal at all for about 15 seconds....then it'd come back up at 4g (full strength) again. It wasn't just once, it'd do this through my time on my phone. Sometimes when I first unlocked the phone and tried to use the web, other times I'd be watching a YouTube video and it'd go in and out on it's own.
What's going on here?
trixie909
