Cyber Warrior
Robots Will Kill
- Nov 28, 2010
- 7,239
- 2,519
- 0
Great write up... nice![]()
I must be doing something wrong. Whenever i put my phone into recovery mode it will show the android with chest open and a red triangle with an exclamation point in it. But it will stay like that for a few minutes then just reboot without letting me do anything else. Am I doing something wrong or did I not install something I needed?
Are you rooted/unlocked?
Awesome stuff Zero Neck! Just flashed my 4.0.4 radios and went smoothly. I am not sure if this would be something to note but flashing the LTE radio was very quick but the CDMA radio took significantly longer, I would say a full minutes as opposed to LTE which took 10-15 seconds.
http://forums.androidcentral.com/ve...nexus-getting-4-0-4-imm76k-5.html#post1753350
You must be on the 4.0.2 radios to flash these. I recommend flashing 4.0.2--REBOOTING--going back into recovery, then flashing the attached file.
Edit: DT also has a file, with bootloader included.
http://rombot.droidhive.com/ROMs/toro/IMM76K_RADIOS_BOOTLOADER.zip
He says ==>
"FYI, It will Flash the Bootloader, Revert the LTE, Patch the LTE to the New and Flash the CDMA."
Thats annoying how you cant just flash it over the leaked version...
With DT's package you. I actually flashed his package just now OVER the new radios, and all is well. He does good work.
This is essentially the new version of the "GET READY PACKAGE" he has for his roms. It also includes the 4.0.4 bootloader, while the other one--I believe--does not.
Therefore, I recommend flashing his package.
