Random apps keep installing by themselves
hey! u can always go for _ flashing your phone software by u r self or get it done by the service center,
that's the only way to get rid of such stuff in an andriod system.
hope u get ur best !!
Hey bro i hve one solution for Sony user....u can re install your os officially to avoid this problem.
The solution given here is already being old ideas so dont give bul**** ideas to member formate,reset and uninstalling app,even child also knew this ******* stuff..
And by formating this error will not completely removed so dont give wrong direction.
Thank you i m working on this solution i wil notify soon
Plz dont share ur rooting mobile idea its an last option and cause damge or can damage your phone if anyone not knowing proper steps.
Hi,
in my case apps that install themselves is because another (preinstalled) app is installing them.
So, in order to remove apps that are preinstalled by the manufacturer (or someone else) you have to do the following:
1.-) root your phone.
2.-) Install adb and fastboot in your computer.
3.-) access your phone terminal (like a linux terminal) by using the following command:
adb shell
--With this it will appear a new prompt something like "shell@something:/ $"
there, you must change the user to "root" (like an admin) by typing "su" at the prompt:
shell@something:/ $ su
after typing that, the "$" symbol should change to "#" meaning that now you have full privileges over your phone system (be careful).
Preinstalled apps are located at /system/app/ and also in /system/priv-app
So if you want to uninstall some of them, you just have to remove them (once again, be careful with that).
you can list the apps installed with the command "pm list packages -f"
Hope this can help someone!
I have this same problem and have tried many times to remedy the problem, all to no avail. Mostly the apps are games, such as Likin Hero, Ten Drop etc.. I just uninstall them and then go off line until it's absolutely necessary to reconnect, then repeat the procedure. It's a pain and I have worried about viruses, but so far I've been fortunate. Please let me know if anyone ever figures out how to prevent this, or how to report it when it does. Thanks. By the way, I love your "Crow" profile picture.
i can help you..
Just Install "ABP." Add Blocker Download it from playstore.
:D
It is working on my Samsung Galaxy S6.
VIRUS BLOCKED
ADD BLOCKED
TOTALLY WORKING
I have the same problem but I fixed by flashing new rom I mean stock rom
because factory data reset is not enough they are still there if you reset.
Kingroot is also good if you can root it so that you can uninstall unwanted apps
I hate it when it attack my phone because they can install and download apps , my phone keeps on restarting when i tried to uninstall something .
In Settings, Security, Unknown Sources uncheck allow installation of apps from unknown sources.
In the Google Play Store app, tap the 3 dots and choose Settings. Uncheck automatic updates/installation. Good luck! It is probably an app you installed which has adware, sometimes they lead to automatic installation of other apps. It happened to me once from either a game app or a flashlight app or something.
Sent from my Nexus 5 using Tapatalk 2
hi every1,
i am facing same problem.my builtin apps or file show ads.and its aritates me.the file name that show ads are
1-Smsmessager
2-Settingprovider
3-Certificate
and apps also automatically downloaded....
please help me.
hi every1,
1-Smsmessager
2-Settingprovider
3-Certificate
please help me.
Welcome. :)
If none of the suggestions in this thread is of any help to you, I don't know that we have anything else to offer.
in my phone when data is switched on or connected to wifi ...some unwanted apps get installed by themselves (including some porn apps)...i hate this and also it consumes my phone storage....now what should i do ..i installed STUBBORN TROJAN KILLER but it says no malware found!...Plz anyone can help me out with this problem?
I have completely same problem. Random apps were installing to my phone, installation from unknown sources were enabling itself, I did factory reset a month ago, but now it´s starting again, Antivurs did not find anything, I´m desperate and don´t know what to do, help !
iam having same problem then i come to know there are three system apps installed in which one was monkey test whenever i clear ram this app
keeps on running it does not stop so i was thankfully able to remove it from my phone and i thing that was the only problem
i have purchased new intex mobile in which this was happening it came installed default
so till now the problem is solved
reply if helped
i will provide antivirus app which will help you to detect the type of virus in your phone if anyone replies
What anti-virus can you help me? Thaks
buddy there are some random app like parkor girl , aple crash , uc news, and speed booster automatically install i thought let uncheck unknown source but after few minutes it automatically activated nd again again apps are automaticaly installed , i reset device 2 time without any backup nd inserted my sd card , what should i do
reply if helped
Same problem. Pls need helped.
Something is wrong.
I do nothing and once a day I see a new app is installed on my phone.
I made a factory reset, then installed only a couple of the most important apps. After that, a month later, it began again. Is it a virus? I don't know, because I install "Avast!" - no warninds, then "Lookout" - it also says no malware is found. The programs it installs look fine, they are not malware at all.
What should I do now? Should I report to any antivirus company?
You have to be careful of some apps you install and read the terms. Some apps especially those downloaded from social media sites say may download a new app per day
mobogine mobogine mobogine keeps installing unwanted apps like netalpha this thing wana kill my phone
racoo
