I'm sticking with the Innocase Active Limited Edition for now. It just seems like the build quality might be a bit higher, and I like the more ruggedness of it. It doesn't squeak, and is a perfect fit. But if it turns out that only the Innocase II Surface will work with their car dock, i may have to switch back.
The dark rubber might turn a bit lighter from dust, but no larger particles have gotten in between the case and the phone yet. I just wipe off the dust if it's been in my pocket for a day.
Very easy. Doesn't make the phone that much larger and the rubber is not SUPER grippy.
Our product group is looking into the possibility to make our car kit and desktop cradle also work with Innocase active.
Thanks
Seidio
i hate cases but i'm tempted to order this one. my only fear is the grit and grime accumulating under the case. those sides on the front look awfully pliable/loose where grit could get back in there easy. i want no maintenance - i don't want to be cleaning this thing out all the time and i don't want the grit marring my phone.
Just ordered mine. Estimated arrival date of 15th. I hope I like it as much as I think I will. I am not much of a fan of buying sight unseen so I have my fingers crossed.
Looks great just ordered mine. I was really hesitant to because I like the phones bare. But the slick sides of the phone make me feel as though I'm going to drop it. Rubber is definitely the way to go. 17th for me. I'll definitely come back after a week or so of use to give some feedback.
well you sold me on it. i placed my order. i figure i can always return it if i don't like it.
thanks again for the great review!
Yes the parts of the silicon which do not contact the 6 clamps of the exoskeleton are a bit loose. However the phone with this case has been in my pocket for 3 days without any grime accumulating. The rubbery silicon hugs the phone just hard enough to provide a slight seal to keep the dust out.
Seidio is consideirng to offer the color Innocase active (color exosleleton) cases what do you think ?
Seidio
Thanks
Seidio
Can I have a car kit that would work with the Seidio Innocase II????
I want to just be able to take my Evo off the belt clip of my Seidio Innocase II and clip the phone into a car dock that has basically the same kind of clip as the belt clip.
I don't really like that active case as I need to replace my battery and that looks like just more to remove and I NEED a belt clip.
Please make a car dock that works with my current case PLEASE!!!!
Note: If it will already work with it please ignore the ramblings of a tired person!! ii
Seidio
It looks like a nice case but personally I would like to see a case with individual cut outs for speaker, camera and camera LED. I don't feel the one big cut out offers enough protection.
Maybe the rugged case will have individual cut outs on the back??
I'd like to see some colors such as Hi-Viz yellow,orange and red. And for those not worried about setting it down and losing it, why not camo?Seidio is consideirng to offer the color Innocase active (color exosleleton) cases what do you think ?
Seidio
I'd like to see some colors such as Hi-Viz yellow,orange and red. And for those not worried about setting it down and losing it, why not camo?![]()
