Thanks Pingpongboss! Btw awesome job on the review. Maybe you can do one for the car kit when its out.
That augmented reality navigation tool looks sweet, can't wait to check it out.
Definitely on my todo list!
Sent from my HTC Evo 4G.
Can't they do the car kit with a dashboard mount? Mounting to your windshield is illegal in California.
V.C. Section 26708 - Material Obstructing or Reducing Driver’s View(12) A portable Global Positioning System (GPS), which may be mounted in a 7-inch square in the lower corner of the windshield farthest removed from the driver or in a 5-inch square in the lower corner of the windshield nearest to the driver and outside of an airbag deployment zone, if the system is used only for door-to-door navigation while the motor vehicle is being operated ( )2.
Just got the case. 1st impression is that it has a very "rubbery" feel to it and the power button is harder to push down. Other than that, the OP nailed everything about the case. Right now I have the White case from the Sprint Store, the Platinum Case from BB and now this one. I'm gonna return the platinum case b/c this Seidio Limited is definitely worth the $25 and the best case of the 3.
PPB - IMO Seidio should send you every case they make for a video review. you probably sold a lot of the Actives here based on your review.
just curious - how did you get hooked up with them for the early review?
I would love to have a red exoskeleton. Being a University of Louisville fan, red and black would be perfection!![]()
Seidio is consideirng to offer the color Innocase active (color exosleleton) cases what do you think ?
Seidio
