Robin's Samsung Galaxy Note 4 Thread
Re: any updated updates on Lollipop?
Everything that I have heard says that the Note 4 will get the 5.1 and skip 5.0 entirely because of the problems Google had with it.
and it should be out by or before the end of January.
I hope you're right as well.
Re: HERE MAPS
Yes it works pretty well if you need offline navigation
Sent from my Verizon Samsung Galaxy Note 4
Re: HERE MAPS
I've been using it since beta. I prefer it much more over Google Maps. I turned off G Maps after about a month of using it.
Re: HERE MAPS
never heard of it till now. it looks nice. I wonder if there is a way to import all my gmaps info. i have a couple hundred places saved that i need on a weekly basis.
thanks for the help
Re: HERE MAPS
Thought it was still in beta.........
Ive been using it off and on. Works pretty well offline.
Re: HERE MAPS
I downloaded this to check it out for a friend that doesn't have any data to use with g maps. I rebooted N4 and still can't get a map to show. Just my locator on the screnen and white background. Do I need to disable g maps? Uninstall/reinstall?
MAY THE 4 BE WITH YOU!
Re: HERE MAPS
Did you go into the App and download the map that you want? I just went ahead and downloaded all of USA but you can do it state by state.
Re: HERE MAPS
It didn't give me this option before but per this post I opened Here again and maps were available. Thanks!
Re: HERE MAPS
So glad that HERE Maps is available on Android. It was one of the big losses coming from Nokia and WP. Google Maps is just dreadful on my Note 4. So laggy.
So far, so good with HERE though.
Re: HERE MAPS
Its fantastic! I love how it stays in the background too...even as I write this :)
Re: HERE MAPS
Going to give this application a shot, I like how I can tap and hold on a location and it stays in the recent location listing so that I can pick it later. Makes picking starting and ending points for navigation a breeze.
getting really impatient about Android L
Before we know it M will be available. I know they have to perfect it...but we were promised it by now.
Re: getting really impatient about Android L
I know a lot of people are waiting anxiously for it and I'm curious as to what feature(s) it brings to the table that you are really waiting. for. I've had it on my Nexus 7 for some time now and it really had made little if any difference to me.
Patience grasshopper. It will come....but probably in March. Right now I'm more anxious for my W2...lol
cepat_tanggap
