[ROM] - 1/19 - SenselessROM 2.0 ICS Edition - Dreams Do Come True
Re: [ROM] - 1/19 - SenselessROM 2.0 ICS Edition - Dreams Do Come
That I can't answer for sure, though Amon Ra seems to be sufficient for all purposes so not sure why you'd change later :P
I probably won't ever need to, I just like to be prepared! :)
And I'm also strangely loyal to applications that I've found useful in the past, and CWM and ROM Manager have always been central to my custom ROM installation experiences!
Haha, I know I used and loved them on my Droid X (as well as JRummy's ROM toolbox, which now has a nifty feature of changing the SD card memory block read size).
I also can't wait for us to get a new kernal and possible support (though unlikely) from Quickclock by JPApps.
16 hours on OEM battery.
Anyone else having great battery life with this?
Just wanted to report that I'm having trouble with streaming media over Bluetooth. I was able to connect properly the first time I tried, and maybe the second. But then it started giving me the same trouble I had with CleanROM, where it would say that the media stream was connected, but the music would play through the phone speaker. After disconnecting and connecting the Bluetooth media connection a few times, it would sometimes reconnect properly, but today I tried about 10 times to no avail.
Just wanted to report the bug, and see if anyone else was having this trouble, and if anyone has a workaround.
Yeah I actually reinstalled SenselessROM last night and tried media streaming over bluetooth and it worked the first time but after that its been a no go.
Sent from my ADR6425LVW using Tapatalk
My battery life is still crazy. After a fresh install, the battery drain is perfectly normal, but after powering off and charging for the first time, the charge just drops at a fast and constant rate. Airplane mode doesn't seem to make any difference. Also, the battery level will jump up rapidly after a quick charge, which suggests that the battery stats are generally inaccurate.
I'm thinking an app has to be causing the rapid drain, but I don't know for sure. Anyone else having similar issues?
Use the battery stats to see where the battery is going.
Menu > System Settings > Battery
byronsss
