[ROM] - 2/5 - CleanROM 2.3 -=ICS Edition=- Clean and Smooth!
<iframe width="420" height="315" src="http://www.youtube.com/embed/AyAcpLufhEc" frameborder="0" allowfullscreen></iframe>
Video preview
Sent from my ADR6425LVW using Tapatalk
just installed it last night,
it seems very laggy.
pictures from my sd card wont show in gallery. but can view them in the file manager
phone is running very hot with no use
battery is draining fast with no use. in an hour after unplug and no use i am at 70%. AND I HAVE THE EXTENDED BATTERY! lol
on the lock screen it displays no service but i have service
after first enabling the lock screen i cant disable it, i always have to use the lock screen code.
Wow, not my experience at all. Did you do a factory reset and wipe your phone prior to installing the ROM?
yes.
any idea on why the pics from my external sd card wont show?
i am now at 51% battery with it just sitting in my pocket....
yes.
HMMMM, I'm not really sure, but this is what I would do. I would go into settings>storage and unmount the SD card, shutdown, remove the microSD card, reinsert the microSD card, reboot your phone, then remount the SD card.
I get about 14-16 hours out of my stock battery with moderate use.
I would also check your apps to see if something is constantly syncing or what not that would account for the battery drain and temperature
no apps are running or updating.
tried mounting and unmounting.
im down to 37% lol.
i wish my new rom im downloading would hurry up so i can get rid of this one.
So you downloaded CleanROM 2.3 ICS, booted into recovery, wiped data/factory reset/flashed rom/after flashing you pressed the power button to install the boot image? Then rebooted? Was this you method of installing the ROM?
not sure if i pressed power button to install the boot image.
because after the install it goes back to the bootloader in fastboot.
edit: ok think i did this as it finds the ph98img.zip and asks to update.
more on this please.
wonder why my pictures wont show in gallery, my sd card is there and mounted and can view the files by file explorer.
Exit fastboot, return to Hboot. It should check the SD card then for the appropriate file, and if it is present then you'll be prompted to install.
yup did that.
i hate my work connection taking for ever to download some different roms to try out
been downloading forever.
Try this, Take a picture of something, then in file explorer find what folder it is in. Then copy and paste your other pictures into that folder, and see if that works. (maybe they are just in the wrong folder)
switched to cleanrom 1.6.5 and everything is working right, pictures show, battery is not draining and not hot any more. not sure what was going on with that rom, i wanted to try out ICS.
Does anybody know how to get the verizon mobile hotspot working? It will not turn on with this rom. It acts like it will then nothing. It works with cleanrom 1.6.5, but I don't like to use my phone as a hand warmer and I like to get more then 6 hours out of the extended battery(im not complaining about Scotts rom just the VZW ota base)). And yes, I do pay for the VZW hotspot. I get it to work intermittently sometimes it says error sometimes it works?
Thanks
After flashing this rom, my battery only charges to 90%...and like someone stated in an earlier post it drains faster than when it did with the stock rom...any suggestions....
Does anyone else have problems with the phone restarting during phone calls? Unfortunately I'm right in the middle of internship interview season and I'm constantly petrified of having my phone turn off during an important call. I'm gonna try reinstalling but I was wondering if this was widespread or just my install.
Let it charge until the charge notification light turns green.
Then I'd suggest going into recovery and wiping battery stats. After that do a few good runs on the battery, going from complete charge to dead.
Get a 3.7v battery. The 3.8v batteries all have this problem with ICS. Either that or wait for the official update. You can also turn the phone off and it will charge to 100%
Maybe I'm just dense but I checked out the Leedroid Tweaks for Rezound post on XDA but I could not find any link to download it. Help please. Thanks. :confused:
Abdullasteki
