[ROM 10-3-12]GingerDX JB UI on CM7+Sense2/3 lockscreen
I'm gonna add Alpha 7 theme and a link to a lookalike HTC launcher.
Awesome awesome battery life. Thanks again TGL.
This could've gone better if I had a full charge and was awake the whole time xD
Edit: forgot photo upload.
This rom really starts to fly with a little tweakage
Interactive governor
Min 480 mhz
Max 806 mhz
Disabled Compcache
Uncheck surface dithering
Check 16 bit transparency
Force enable scrolling cache
Check allow purging of assets
Check ksm
Uncheck lockhome
Uncheck lock messaging app
32 vm heap size
Haven't really tested battery life that much yet but noticed no drastic drains. Is incredibly stable during browsing, videos, tapatalk, and camera while tethering! Not that my opinion really matters but I am incredibly impressed. I can't thank you enough :thumbup: :beer:
Sent from my SPH-M910 using Android Central Forums
Re: [ROM-PORT] GingerDX CM7+More Features!
Min 480 mhz
Max 806 mhz
Disabled Compcache
Check ksm
Uncheck lockhome
32 vm heap size
Running very similar settings.. this thing is great. Thanks so much.. 3 hours from full charge moderate-heavy usage and used 15% battery.
do you have repos out there for your work? I was curious about some of those tweaks you've got goin' on
I don't know how to build, so I have no repos. I port simply using APKtool, and WinRar.
so did you download it from someone's source or I guess you're saying you used another some sort of way to port it
Straight from the actual thread by EagleEyeTom, I still have to edit the post.
Xperia X8 Original Android Development, GingerDX. I'm trying to learn how to build from source.
Re: [ROM-PORT] GingerDX CM7+More Features!SENSE Lockscreen,Battery Bar,S3 PickUp to Answer
I'm so stuck between this, GingerSnap, and MiRaGe.... D:
Same here. They all use Mirage as base, so that helps to pair down the decision.
Decisions, decisions... A-android-B's way awesome setup seems to make me want to flash this even more...
Hey OP got a link to that HTC style launcher yet? Rom is amazing
Like Sense v4?
Re: [ROM]GingerDX JB UI on CM7+Sense2/3 lockscreen
Update is up
http://db.tt/3XvennP2
Jelly Bean UI on CM7!
Tapatalk wont lemme upload to Forums or Hosted by it. Ill upload Screenshots later today.
Pogojeal
