[ROM 10-3-12]GingerDX JB UI on CM7+Sense2/3 lockscreen
For some reason I lost root with the latest update I tried super such twice no go and then I tried supersuer and it didn't want to update binaries
Sounds interesting:D downloading now!
Post screenshots if you can. Tapatalk limit prevents me. Jelly Bean UI in Status Bar settings.
Thanks! I just noticed. Ill fix when I'm done my homework :thumbup::);)
No clue why. Everything that needs superuser automatically denies, checked the settings. It's set for prompt, yet it never does. Installed the Beats audio. Sounds great and I like the rom too!
Edit: Superuser says I've lost root access. Weird... reflashing. Hopefully the rom just derped.
I just installed the 10-03 Ginger DX rom and it is great. I solved the root issue by flashing a Super User zip in recovery called su-3.0-efgh-signed.zip. I forgot where i found it , do a google search. I think that I found it last year when I couldn't get Super User to work correctly on a Froyo rom.
Here I am, trying to do homework myself, and your freaking awesome update distracts me!!!!
Ahhhhhh!!!
But seriously, keep it up, bro. This is just getting better and better!
I failed at pushing out what I said. :(
Its all gravy tgl, homework should probably be top priority anyway. There will be another day I'm sure. Love your roms dude and make sure to have fun!
I'm having probs with root permission on super superuser and regular denies any permission need help thx
New screenshots added!
NEW UI
Tgl no matter how hard I try dsp manager wont even open
I pushed to system with right permission it shows then it just closes no force closes just close. Suggestion
Is the JB ui baked into the framework/system ui, or might there be a flashable zip I can use to get the same effect on base MiRaGe?
Unfortunately, no. Achep took over GingerDX, so maybe he can make a patch like ICS statusbar on CM7. We'll have to see what his next plan is.
When did he take over?
stopwatch
