[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.6.1 - 10/5/11- GB 2.3.4 - Rockin' the Beats!
Hmm sorry I should have read more closely. I will have to check that out as well
Also, animations on websites are not working, and I have checked my settings, and they should be good to go, as they were before I flashed.
Hey just noticed that as well...hummm. Hope another update is coming to fix these two issues. Don't want to try another ROM again! The battery life is awesome!
Ok when I flashed this ROM from a clean install Adobe Flash was working. I am noticing that flash has stopped working on my browser. Anyone else notice this?
Nevermind..it's working! Cleared my cache and back working!
Heck, dude, I didn't turn on gif animations in my web settings after I flashed. Duh. Try that, it worked for me....
It looks like I lost the weather animation and the icons on my lock screen, I did a full wipe before I flashed. Any ideas?
Anyone else's hotspot not working? I flashed it correct but It keeps telling me i'm not suscribed to hotspot. :-\ ....I know that wifi tether is included...does that mean just use that app instead?
You have to redo them if you did a full wipe. They don't carry over.
Sent from my PG86100 using Tapatalk
Nothing is there even when I go to setting and re-assign them. The weather animation is gone also. see attached.
I don't know then...I just go back and reassign my lockscreen items and set the weather as my lockscreen background and they work fine. I also use the weather live wallpaper. Maybe someone else can chime in on this one?
Anyone else hate beats audio? I was waiting so long to get it and now that I have it, I hate it. My music sounds awful now. All it does is crank up the vocals and bass. My music has no mids. Then HTC tricks you by putting HTC audio enhanced on there which sounds even worse like everything is turned extra low. I want the option to delete or turn off beats and all enhancers. I liked the old setting where there were no enhancements.
I pulled HtcMusic.apk and HtcMusicEnhancer.apk out of CleanRom 2.5.1 and put them into 2.6 (wasn't sure which one it was so I just did both). Beats is gone and the fake beats (with all the music type selections) is back and sounding great. Get both apk files from the /system/app directory in the CleanRom zip file. Place them in /system/app on the 3D and overwrite what's there (I did it in ES File Explorer). Then boot into recovery and clear the caches. That's it. I did the same thing with the camera since the iso speed selection was taken out in 2.6
Does this ROM allow you to overclock the EVO 3D? Sorry I'm a n00b at this. I'm digging through this thread right now to look. Just posting just in case it's not here. Thanks.
CleanROM 2.7 Now out!
Changes in version 2.7 - 10/19/2011
Changed: Kernel Bcblend v3 with Dim capacitve lighting and always on notification
Added: Hacked Sprint Hotspot
Added: Camera with Sound On / Off toggle
Added: TV Out
Added: Screen Calibration
Updated: Adobe Flash 11.0.1.153
Removed: Beats -In ROM Updater Soon!
Removed: Overscroll - In ROM Updater
Please Hit Thanks if you like this ROM. Hit the Donate button to show how much you like it :D
Re: [ROM] CleanROM 2.7 - 10/19/11- GB 2.3.4 - Cleaner Than Ever!
People App crashes in 2.7. I did a clean wipe before flashing.
I had this problem on 2.6 initially. It was a simple fix, but I can't remember what it was. I am very helpful.
chzahid600
