[ROM] 11/24 - SenselessROM 2.9.5 -GB 2.3.4 - Wow! Just Wow!
Re: [ROM] SenselessROM 2.2 -9/7/11- GB 2.3.4 - Now More Senseless
i am not able to edit contacts after the update
lol... Ummm. Yeah...
Note: HTCContacts were mistakenly omitted from the ROM. I have attached a ZIP file to thed OP to be flashed in recovery. I will post a ROM update soon to include the missing file. But for those who have already downloaded and flashed... Whooops, sorry!
Reactions: kevnutz
thank you worked perfectly.
i have a quick question. for some reason i am not able to change my notification tone. I pick another stock tone and it will not change. any ideas?
I think there is a super secret setting for that, lol... Ok maybe not super secret but there is a specific setting for different notifications. I am not on ROM right now, doing some testing of other things but when I will flash back over later on and tell you exactly what I mean.
Bam! Whats up now?
WOOT!​
Way to go man ..I've been flashing your roms since winmo days
Reactions: scrosler
any luck with the super secret setting?
I can only assume that you are referring to the messaging notifications? Go to messaging and select settings then notification sound. They are set differently than the general notifications.
If you are not referring to messaging notifications please tell me the exact notification you are trying to change.
Downloading now! I found an issue in the older version with the sprint hotspot app. Even in an area where I have 4G signal, if i start the hotspot, it will start with 4g for about a second, then disconnect me from 4g. from there on, if hotspot is on and i click search on my 4g settings, it will find something, show connecting to sprint for a split second, then hop back to disconnected again. I will let you know if it is still present though
The Sprint HotSpot does not work on 4g. For 4g tethering you will need the WiFi tether app mentioned in one of the stickies.
Reactions: scrosler
How is this pure AOSP? Did you compile the code? If so how did you get visual voicemail working?
Its not pure AOSP. Its sense based with AOSP theme. And most of the sense stuff removed.
So stock gingerbread but with htc Widgets? Wow that's nice. Although I still see bloat, such as media share and other stuff. I think it should just have gapps and whatever you don't have the time to take out of the framework.
Sent from my Nexus S 4G using Tapatalk
Oh! And heard there's a way to make data faster by removing some sort of idle governor.
Yep, stock-ish GB but most of HTC stuff gone. I removed the widgets and Rosie for the most part then re-themed what I am capable of.
I wont go the pure pure you are suggesting because the RMO is more so inteded to be an AOSP close than true AOSP. Media share adds value to those that can utilize it.
I tried this out last night..
It seemed ok at first but it had major issues.
First off, like CleanRom, it downloaded a number of apps when I signed back in but had the "insufficient storage" error. It doesn't matter if I wiped all data and caches before and after installing the zip. I did it twice to the same problem.
Secondly, there were a number of apps in the Market that I could hit the "Install" button on but it would never resolve to the "Accept and Install" button. Things like ESPN scorecenter, Google TV, and other not very insignificant apps never could find the full install.
I'm not sure if that's a problem with the ROM, but I definitely didn't have that with other things.
Just would like to clarify some points.... Sorry to hear you are having this issue!
Maybe google was having some major issues. This ROM was tested thoroughly by a number of people (including myself) and none of us saw the issue you are describing. I am not however, discounting them because they do pop up from time to time for people one new install.
Generally what you are seeing is the typical problem with all the Market 3.x series. I personally have had the slow to download issue happen once or twice and a simple reboot and wipe of cache fixed it but even then its rare for that to happen to me.
I have never had the out of space issue. That is normally caused by a bad wipe or not wiping at all.
Google is great at some tings but... Writing the Market app... Not so much! lol
-Scott
Ok...
I cleared the caches, updated to 2.3, and the market issues are gone. Except for a bunch of Go Launcher themes I had are no longer in the market. Very, very weird but I highly doubt that has anything to do with the ROM or maybe not even the market app itself, since they're missing from AppBrain also.
So that's good, I can use the market fully again.
Now, here's a couple issues I'm having and I'm not sure on the cause.
#1 When my alarm went off this morning I didn't see the familiar SNOOZE - DISMISS buttons like in Stock/Clean. Hitting the power button snoozed it and I had to hit it in the notifications to turn it off. That was odd
#2 When I got a call while my phone was locked, I had to unlock it first, then I could answer
#3 The lockscreen.. Maybe this is the reason, and I saw earlier that you had the HTC Lockscreen as a download, but I don't see that in my list of extras in the Rom Updater.
And #4 in the rom updater app, when I was running CleanRom the latest rom showed Senseless 2.3, and now that I'm in Senseless, it's showing CleanRom 2.5. Weird.
achongpius2022
