[ROM] 11/24 - SenselessROM 2.9.5 -GB 2.3.4 - Wow! Just Wow!
Who is pecord?
Can someone from... | Facebook
Who is pecord?
ClockworkMod One of your fans may have uploaded it?
"pecord" is the developer id I see listed.
ClockworkMod Incidentally, he is not pulling from your server, it's uploaded to mine.
Scott Crosler I see... Thank you for confirming this. I was worried you took it without permission. Sorry to bother you but thanks for the replies!
Who is pecord?
So this means someone else uploaded it correct?
BTW your up to 189 downloads on ROM manager.
Sent from my PG86100 using Tapatalk
Re: [ROM] - 8/4 - Senseless ROM 1.1 - A ROM with No Sense that Ro
Am I missing something? I drop .zip in root, wipe/factory reset/cache/dalvic back up gapps and install... It says its opening and then stops
Cool. The ROM has been mirrored so many times its no longer possible to keep track of it any more. Did you see the links a page or two back? I guess I will stop being a cry baby now. lol
Yep, as long as you are twrp'ing it.... Drop zip on SD Card go into twrp wipe data / factory reset then install zip. Reboot. Enjoy.
Wow no I didn't till now. Looks like you are da man! Hopefully those people show their appreciation ;-)
Reactions: scrosler
Nah, i'm getting an error E:Can't open /tmp/sideload/package.zip But I've tried downloading the rom like 3 times and flashed it like 10 times..
not running custom ROM or kernel, as of yet. I'm running.1.40 shooter build
Did you reboot and try again? That was the fix for others exp the issue.
Well... i forgot to perm-root it (palm to head), last night when i did this all at 3am... But it wouldn't work, and then I... I don't know what I did, but it works now.. i wish I knew why lol
Strange! Things happen... At least you got it going!
Re: [ROM] - 8/1 - Senseless ROM 1.2 - A ROM with No Sense that Ro
Version 1.2 is now out!
Updates in Version 1.2
Task Bar Icons fixed, Added More Quick Settings, Updated Adobe Flash, added Gtalk with Video (WiFi or Network Data)
-= Please provide feedback on the new download links! =-
Have fun and please consider donating so I can afford a faster server :D
And please hit the THANKS button :D
Donations always accepted but never expected!
Re: [ROM] - 8/10 - SenselessROM 1.2 - A ROM with No Sense that Ro
When updating to the new version of the ROM, do we have to repeat the same process and wipe everything again? (I'm a newbie at this)
EDIT: Never mind.
EDIT: Never mind.
Purists will say yes, I'm sure Scott will say yes to avoid any potential headaches but I never had a problem not wiping if I am installing the same ROM especially if you are not changing the kernel. I am still running off the same info from my unrooted stock 3d software. I figure if I run into problems I have plenty of clean backups tucked away in my SD card and my computer. (Ducks as scrosler takes a swing).
gulbhahar36
