[ROM] 11/24 - SenselessROM 2.9.5 -GB 2.3.4 - Wow! Just Wow!
Re: [ROM] - 8/10 - SenselessROM 1.2 - A ROM with No Sense that Ro
Wow, let me guess.... Your the guy that I just had banned a few days back and now you are here to flame again?
If you took the time to READ instead of shooting off at the mouth the first post CLEARLY says there are remnants of HTC. Just fyi, Sense is not spelled sence. I also have a suggestion you and your flaming attitude....
Before posting...
Read, re-read... Then just dont post.
Thanks for your very inaccurate feedback. Have a nice day!
Dont even reply.. Ignore it and report it.. otherwise it only makes you look bad. Trust me I had to learn this too :)
Oh, Im still havin issues w the lock screen... did a full wipe and flash and still issues.. slider goes vertical...
Good! Because you made my day too!
Try mailing it in with your ISP bill :D
Also, with the stock homescreen, the bottom thing with the phone, app drawer, and globe, is it possible to make the globe open my preferred web browser instead of the stock one?
Whats your default browser? Generally speaking... When you install another browser (or any app for that matter that already has a replacement on the device) it should ask you to choose a default when you select that action. If that did not work for you let me know the browser and I will investigate.
Adw or the like will allow for this customization
Sent from my PG86100 using Tapatalk
Should not need that. Currnet laucnher shoudl be able to do it as well.
*cough Go Launcher EX cough*
You know what you are correct. To bad you didn't post that before I went off, lol. Oh well.
When you say slider goes vertical, can you cap the screen and post or explain more? Also, did you apply any framewok-res mods? I will check it out now. I got a few minutes on lunch.
I didnt apply the mod...
The lockscreen pull tabs... the left is for the lock. the right is for the audio. The RIGHT audio slide tab is vertical.. so the IMAGE isnt horizontal... should look like this on the side of the right screen " C" but looks like this " U " . LMFAO.. sorry dont have a way to send u an image of it.. but basically the PNG file keeps flipping itself...
I just tried it like 50 times and its fine on my side. Are you using the beta preview I sent you a link to or are you using the one posted in the OP?
I linked you a beta preview for testing but never heard back from you.
I saw the beta link, but I used the OP link since u released it before I looked at it... its strange.. I may b the only one w the issue tho... ima do another full wipe and flash
IM not saying its not there. I am just saying I am not seeing it.
Ever use ddms.bat in the SDK? It allows for screenshots whenever ADB is connected. Its what I use for the postings. http://www.knowyourcell.com/htc/htc...ow_to_take_screenshots_on_the_htc_evo_3d.html
I call shenanigans! There is no way that is happening on a fresh flash. No.... IMPOSSIBLE!
It has to be something you are installing. Did you change the wallpaper manually or with a mod?
Your pulling my leg, arent you?
I used the stock gallery to choose my background.. idk what the heck is goin on. Only thing different is that im using Launcher Pro. Ima try to remove it and see what happens...
and now i dont even have the LOCK image on the left... very odd..
UPDATE - I now have it back to normal.. its totally random.. still gonna get it to happen again and remove Launcher Pro
Im gonna download launcher pro now and test...
Downloaded launcher pro and no issues. Changed background with Launcher pro and with gallery. No issues. For that to happen something has to be modifying framework-res and causing it to rotate that one png
EXACTLY! Thats why i am stumped.. and now its fine again and cant get it to recreate it lol.
Um.. did notice something tho about the locker. If you hit the menu button.. it unlocks. You dont have to slide..
You need to relock that phone and tell Sprint to replace it. It must have a bios level virus that rotates and deletes pings at will :eek:
Wow I just tried this it I get the same thing. I flashed my very first nandroid backup and it was normal. Flashed backed to senseless and it returns. My lock screen tab goes missing intermittently but when I swipe the action still unlocks the phone. I have been meaning to bring it up but always forgot about it.
Well its not a virus... Just wonder what the hell
Sent from my Carrier Pigeon using Tapatalk.
Here is a quick video of the problem. I am flashing back to my stock rom now to verify that the problem goes away.
VIDEO0029 - YouTube
Winnix
