[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
I'm definetely going to flash this when you release it, and I don't change ROMs, like, ever! I think I asked this before, but it got lost in the thread, but is there an extended settings that works with this? Or is there a way I could help port one over if not?
Thanks Gannon!!
Tapatalkin' it from my IHO CM7.2'd MIUI Themed Optimus V
Reactions: rukin5197
Re: [ROM][3/23/12][2.3.7]MIUIgb! By team A.P.P
Thanks Gannon!!
I personally haven't tried Extended Settings but AJ claims that he's tried it and it didn't work. So, there's no telling. I'm porting it as we speak, so I'll test it now. But I'm sure it wouldn't be too difficult to port over if we tried hard enough. The only problem is that they're version specific and we don't know what version this MIUI is.
Do i need to flash gapps with this?
Couldnt find any posts about it..
let me know :p
Thanks, but so as of with the latest build
Camera/Mms doesnt work?
Im fine with that, and i hear there is a workaround with themes?
Check OP.
Guys, I may have the new build by tonight. So keep on the lookout. Translating this is sure a pain!
Really hope there's a update tonight, we appreciate all your work. Will this include working themes as in the application?
Who doesn't like a fancy lookin' device
Just ported it and a few updates:
Camera still freezes :/
Lockscreen hdpi themes still don't work (Going to look into this)
Statusbar themes are working (Might need reboot)
Themes are working without the fix.
Updated version of MIUI (I think)
Is it deserving enough to release? Or should I fix one of those first.
I think that the people that follow this thread are ready for any release, they're a bit tenacious about your ports.
Fixing the themes so they don't need a workaround seems significant enough to me to make a release.
I say do what you have to do. :p
Also, the whole UI, is it fully MDPI? My market force closes when I click a app, such as Xda premium.
Some of the overlay text is also black on black.
Other than that, I'm still in love with it. Getting into theming now :D
I think you should wait until you fix some of those. I know I wouldn't mind waiting
Sent from my VM670 using Tapatalk
I agree. Not that I'm not excited for a new release, but go ahead and polish it up a lil' before before releasing, imo. Of course, do what ya want! :)
My biggest question is actually regarding MMS, do you currently have that working?
Here's just some things i've noticed while using this rom which may or may not have been covered already:
  • Camera doesn't really work. It crashes on me all the time. It usually starts up fine, there's an image on the screen and everything seems good, but adjust the zoom or adjust settings and it will freeze and give option of Force close or wait. If you wait, image will remain frozen eventually force close or wait options again. When you force close and try to restart Camera, it says Camera Error: Cannot connect to camera.
  • Battery icon randomly appears and disappears in the status bar.
  • When trying to view and change options in some apps, the menu will have black background with black text, and you are unable to read anything unless you select where text would be which then makes it momentarily visible.
  • Under Settings>System>About Phone, selecting Status displays only Open Source Licenses, CyanogenMod Licenses, and Google Legal, instead of phone and network info (maybe that is just a MIUI thing, not sure), Selecting Battery Use has no affect and displays nothing.
  • Can't figure out how to permanently get rid of "Roaming Indicator Off" in the status bar. It goes away when the Juice Defender icon is displayed.
I think there might have been something else but I can't remember right now. Again, these things may have been already discovered, so if pointed out something that's already known, let me know.
Just a thought... the whole battery disappearing seems almost like the status bar icons for the battery don't match what the indicator is asking for... like it wants a different icon for each percentage and the framework is only giving it a different icon every ten percent.
Its just a thought.
Sent via the Postal Service
Any chance of making UI menus a bit smoother? The system menus for example are a bit laggy.
does anyone know of a replacement launcher that allows theme changing to change the icons? i really like this ROM but i just can't stand the default launcher. it's slow and i want an app drawer, lol!
App drawer just isn't MIUI. Sorry. And the themes change the icons?
Yeah with 3rd party launchers, I noticed the icons don't change when applying a new theme.
Sent from my VM670 using Tapatalk 2 Beta-4
Status
marik999
