[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Re: [ROM][3/29/12][2.3.7]MIUIgb! By team A.P.P
xxlemonxx 07:14 PM Today Can someone post the miui camera apk? Don't feel like re flashing and downloading all my apps
+ 2nd to that! ! Thanks
Gannon everything works for me but I can't get the flashplayer apk to install. I really like this and not having the flash I wont be able to make this my daily driver, do you have any ideas on getting it? Thanks for a great job!
Sent from my LG-VM670 using Tapatalk 2 Beta-4
Put the flash player apk in system/apps and set permission are rw-r-r, could you or some one please post the miui camera apk thanks!!
Ha. So I downloaded the Suave HD theme and apparently it was for the wrong phone or something, and the lockscreen was reaaaally big. That made it unable to unlock my phone. I feel so stupid.
i think to unlock without the lockscreen its volume down+menu if that doesnt work try volume down+back
I flashed the latest and the battery indicator isn't showing up. Any fix?
The battery indicator showed up for me.
....and it literally disappeared as I was typing this.
Also, is there a way to change the "Virgin Mobile" logo? The custom carrier option won't work.
When applying a theme, uncheck lockscreen. The nice thing is, if you have milocker installed, it will automatically show the same lockscreen in your local tab. Just apply it there and it will fit your screen perfectly.
Is the notification toggles theming for any one else, this is what mine always looks like with every theme I try
This should be my last question. :P is there a way to just theme the messaging app?
Go to the theme store and choose customize at the bottom, then select SMS. Then pick the one you want.
Re: [ROM][3/31/12][2.3.7]MIUIgb! By team A.P.P
My toggle theme find! Just go to themes and then customize and choose toggle or which ever one you want or just theme everything ;) once again thanks gannon!!
Status
sukarisw12
