[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Its a tool included in the android sdk for compiling and decompiling apps. Its awesome. Google it.
Sent from my VM670 using Tapatalk
Re: [ROM][3/31/12][2.3.7]MIUIgb! By team A.P.P
anyone have any luck getting the built in wireless tethering option working?I also tried wireless tether for root from market and it seems to only be able to do wireless tether via adhoc witch seemed pretty unstable to me,also since i have not red every page in this thread is there any fix for my battery info not showing up in status bar?would love this to be my everyday driver seems its so close,also is mms working for everyone i didnt get a chance to test that b4 restoring my backup
I've been trying for weeks now to get this thing running... I keep downloading the latest release and flashing it same day, but in settings, when I press device settings the settings app crashes. Settings are the most major part of a ROM to me, and since they don't work fully, I will not use the ROM. Great looking, runs smoothly, but the settings throw me away from it. Please fix soon!
I like it a lot it's sweet looking but device setting and location change causes instant fc. Also one of my most important app is viber and it never starts. fc immediately. Do you what causes it and how to fix it?
does anyone know of a way to get scrollable widgets to work with the default launcher?I tried android pro widgets but I couldnt get any of the widgets to scroll...
update:using android pro widgets that are 4x2 work and scroll as long as u uncheck the native scrolling in options of android pro,the 4x4 widgets seem to not be sized correctly an therefore you wont be able to see the button at the bottom that allows you to scroll.
does anyone know of a way to get scrollable widgets to work?I treid android pro widgets but I couldnt get any of the widgets to scroll...
I believe that the scrolling ability is determined by the launcher.
EDIT: I'm using it with ADW right now and having no problems.
There's a small fix for the battery indicator! Go to settings-personal-toggle and scroll down to battery indicate, and choose battery bar :) I also have a few bugs to report, miui gallery when trying to set lockscreen picture it FC, 2 wifi hotspot not working 3, FC when going into device setting! Awesome build 3/29 thanks gannon
Edit: found a way to set lockscreen wallpaper! !
There's a small fix for the battery indicator! Go to settings-personal-toggle and scroll down to battery indicate, and choose battery bar :) I also have a few bugs to report, miui gallery when trying to set lockscreen picture it FC, 2 wifi hotspot not working 3, FC when going into device setting! Awesome build 3/28 thanks gannon
It seems as though bugs 1 & 2 have been fixed as of the 3/31 build. I haven't been able to properly test bug 2 since I didnt havr anything to connect to the network though. Device Settings still gets a FC.
Reactions: Badboytoast
Can I just wipe catch and delivic and flash the new build! Thanks
Nothing's wrong with the gallery, its just our phone. Slow SD speeds. The settings that force close aren't important. For example Cyanogenmod settings aren't supposed to be there. Battery Indicator works, just not below 100%
Sent from my LG-VM670 using Tapatalk 2 Beta-5
Edit: Nothing's was wrong with lockscreen wallpaper,it does work.
@curious noob
Updating to 3/31 as I type this! Like I mention before I was using 3/29 thanks tho, and yes there SMALL, Tiny bugs ;) thanks didn't mean to sound demanding! Just thought ill trough it out there!:)
Bug 2,hot spot broadcast but will not fully connect to the internet,not sure what the problem is,wireless tether for root seems to work via adhoc witch I can not stand.
Hotspot is indeed not working, but its not official MIUI. Its still CM7.
Look on the bright side. VMs network finally got good with the speeds, while hotspot will dominate your speeds. :p
wait so this isnt MIUI? and anyone else run into the markeet wont download issue
This is MIUI, just not official. That's why it has Cyanogenmod settings. There really isn't no bugs, its the fact that MIUI is HDPI and this is ported.
Status
sukarisw12
