[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Yup, just install one, hit home and set it as your default. That works for me anyway, with Go Launcher EX.
Re: [ROM][3/31/12][2.3.7]MIUIgb! By team A.P.P
So does mine it randomly restarts and sometimes the screen goes all static :/
Overclock lower, as the theming takes up ALOT of ccpu. Im overclocked at 480-600 On Demand.
Sent from my LG-VM670 using Tapatalk 2 Beta-5
I am on stock clock, it still restarts. Sometimes even when I'm not using the phone.
Try a full wipe! And you should flash gapps with it, yes I know gapps is include ;) but it works for me with out no problems ;) it might help!!:)
http://goo.im/devs/ajrty33/roms/heroc/miui/heroc_miui_beta6.zip
ok...
stock browser works,
battery icon works,
dialer changes with themes, call ui still doesn't
toggles and pull downs theme (icons and background now)
includes some resized widgets (jasonevil)
edit: fixed translations in the settings :)
oh, also includes miui media files (ringtones, etc)
oh and you shouldn't have to flash this over beta4. should flash and boot no matter what.
Expect an update of this soon. Most likely today.
After that, everthing should be fine.
Good :)
Now to work on v4
Good :)
Now to work on v4
I can't wait to try this again, especially since Jerry Script posted about how to fix the low memory market error :). Thanks for all the hard work you do.
If you guys want good lockscreens, search for Mutia on XDA and deviantart. He makes MDPI MiLocker .mtz :D
Reactions: rebel69ization
Click to view quoted image
And me! Search me too! I have one ported to MDPI and will probably posting a new one this week. I'll take requests as well, so long as the lockscreen isn't too complicated. I can do like 1 a week at this point lol. I'm getting better.
Re: [ROM][4/04/12][2.3.7]MIUIgb! By team A.P.P
Updated OP with new build.
Going to go back into Win7 to photoshop some stuff for my liking :)
Sahweet. I think I'm finally going to try this version. Any REALLY bad bugs?
I believe MMS and Roaming Indicator Off are the main ones. I could fix the RIO really fast but it takes forever to upload so I said screw it.
It depends on what you're definition of daily are.
I run this rom as a daily no matter what since day1. I use miui v4 theme with different home themes.
I actually prefer the white and orange....
Ill probably fix stuff on my own
Alright. I can easily change the Roaming Indicator off. I use phono for a carrier logo anyway so that gets rid of it if I remember correctly.
I like to mix and match but now that I have some free time I'm going to make my own themes
Sent from my Amazon Kindle Fire using Tapatalk
So... can anyone confirm MMS is broken? I don't want to install the update and lose a feature.
What was wrong with the battery before, anyway?
Status
Xpornefar
