[ROM][5/23/12][4.0.4][AXI0M] CROSSBREED and PATIENT ZERO
So far PZ vz15 has been functioning great.No Fc's ,no lags I noticed yet.I did fix the script error but still the battery isnt lasting as long as it did on 14.
I upped the volts cons.gov.
I can live with bsttery issue ,til update is out.ha :)
sent from me using TapaTalk_2_beta-4
Re: [ROM][3/27/12][4.0.4]AXI0M Crossbreed & PATIENT ZERO
I flashed Zero Patient last night. It was running great, except the screen looked kinda blue. I tried to adjust the color using color multiplier tuning under rom control, and it didn't really do anything.
You should start by upping your voltages +25 across the board. These ROMs are seriously undervolted, and stability seems to go out the window over time. Increasing those voltages will usually make your phone happier.
I don't know that the color tweaks ever worked. I see no bluish anything with mine.
Reactions: 6spdtls
I added +100 acroos the board. It's still the same. On the other hand, crossbreed had no blue coloration on the screen.
Re: [ROM][3/31/12][4.0.4]AXI0M Crossbreed & PATIENT ZERO
Yeah there will be an update to the update for v16 tonight .
Currently the lockscreen target is just showing half of it on the bottom of screen,you can still slide it and its functional tho :) so can answer phone .
Also the market isnt letting me update or download anything .DT is aware of these issues and said an update should be out tonight to fix it.
Im still on V16 dont really need anything from market as of now,gunno wait for update to it.
Its running great ,, just a little more tweaking to fix a minor bug or two.
I noticed the same market issue with AOKP build 28 I think a week ago then updated to v15 to get my market working. I think I'll wait for the update tonight before going to v16.
edit - looks like the inverted google apps fixes the market issue for some.
Sent from my Galaxy Nexus using Tapatalk 2 Beta-3
quite possibly a noobish question after putting this on my phone now when i connect to my pc it no longer recognizes my phone... any ideas ???
Reactions: lindsey328
Check to see if debugging is on in Developer Options
Weirdly enough, my stuff isn't showing up either. Noticed it in the gallery, now notice it when it's plugged in.
Does anybody know how to increase the volume when using Bluetooth headset with the stock voice dialer. Its very low!
I'd suggest using franco's kernel with the sound increaser, OR downloading the Volume+ app and using that.
When you flash the get ready package first (radios) do you need to reboot before flashing the rom itself or can you just flash it right away?
lol same as in the CM thread, no reboot in between is necessary ;).
Reactions: shanedroid1
lol thank you i appreciate the help. I figured twice the posts double the chances for a response :p
D, you've got a monopoly on [ROM] threads. :)
avromo
