[ROM][5/23/12][4.0.4][AXI0M] CROSSBREED and PATIENT ZERO
Re: [ROM][3/20/12][4.0.4]AXI0M Crossbreed & PATIENT ZERO
I dont lurk over there. Too many sites to keep track of. Basically just do AC and RW, in that order. :)
Its out... and its GLORIOUS :)
Integrated beats audio, Voice Talk from the Galaxy Note, fast as a raped ape, new UI is SWEET... but those of you who whine about wanting the Boring UI will probably whine even more... lol :)
This may surprise some of you (or maybe not who knows), but I am a seriously devoted fan of hip hop. So beats is nice for that bass.
Pt 2 - that's me. but im about to load up the ui package anyway. I'm actually warming up to it
Haha awesome.. you won't be disappointed this thing is running sickly for me... Give the UI a chance to warm up to you.. get absorbed in the sexy blues and deep blacks...lol :D
nice im lookin forward to it. should be flashing up and running in about twenty min.
i gotta see the changelog, curious what he did with the undervolt settings this time around.
Big reggae fan myself.. I listen to a lot of everything though. Testing some beats out now and loving this stuff.....
In case you (or anyone) misses it mentioned in the droidhive thread.. The Beats Audio is fully integrated. So just use DSP Manager to select what you want in terms of equalizer, bass boost, etc.. and let it do its thing. Make sure you set for Phone Speaker and Headphones (their in different panels) :)
Reactions: zero neck
I dabbled in reggae for a while but i was more into dub. like, Scientist, Lee scratch perry, so forth.
Gotta check out beats. had it on the tbolt after the rezound came out but i think there was something screwy about it.
PZ builds have the Trinity kernel right? The last M2 build with Franko's M2 kernel would cause my phone to not wake up and a battery pull would not always fix it.
I am on CND right now but it is not the same.
Axiom is typically more aggressively undervolted, and may cause more lockups and screen of death. If you raise the values some that might solve the problem if you're experiencing it. 2defmouze posted his settings a few pages back which you might want to check out for a reference if you're interested (i believe the settings he posted were on pz 14 not m2 however).
Well my foray into gummy lasted for about a day and a half. :-/
V15 is running nice.
Sent from my Th3orized GN
I've been pretty lucky with the voltages. The last 3-4 ROMs have worked well with the assigned levels. Each ROM I end up thinking this might be the one I stick with, but they just keep getting better.
Re: [ROM][3/27/12][4.0.4]AXI0M Crossbreed & PATIENT ZERO
Any major changes? Differences?
Just updated the thread, may flash later today (phone interview in 30 minutes--wish me luck!).
Read the changelog, noobie
Lol jk :)
Many changes, much snappier, new very Blue and Black UI, integrated beats audio, galaxy note Voice Actions, and more.. :)
Oh wow. Looks like I'll be a-flashing.
What's so special about the Note's voice actions? And can you turn off Beats audio? It's terrible for most music lol
lol I refuse to register there out of principle at this point ;)
I don't believe you can turn it off, its integrated... though I'm sure you could hack something if it bothers you, maybe some system file can be frozen in TiBu... idk though, if anything is overwhelming or hurting your music just use DSP Manager to adjust the settings/equalizer/etc.. Might take a little time to find the perfect setting but probably worth it. I've been listening to music all morning and appreciate the touches (though my earbuds and car system probably don't even do them justice, tbh).
The note's voice actions app, from the little I've used it, just seems to be a nicely polished voice control app. Its based off vlingo, if you ever used that. I set my long-press search to just use it now instead of google voice actions.. seems pretty accurate and has more options than the stock voice actions. One thing to note... When setting it up it will give you the option to change the "wake up command".. don't do that as it seems to be causing the whole thing to force exit if you do, just leave it default. If anyone already has, simply clear data from the app and it will go back to normal/working mode.
Oh here's the full changelog btw in case you need it:
3/27
Rebuilt ALL Of it
Trinity NP 3072 Kernel
Integrated BEATS Audio
Updated APPS
Text and Image Enhancements
Tightened Up CMPLXTH3ORY Script
ReWorked INIT.D Startup
Trimmed Some Fat
New Twist on Battery Tweaks
First Wave of AXI0M TRIAGE UI
New Hacks and Tweaks For Testing (Leaving It UnBias)
Added Voice Talk (Galaxy Note)
MANY System, Trans, and OS Tweaks.
Smooth as a pimp!
Looks like a pretty good update and if it's smooth as a pimp there is no way I could skip this one ;)
Well, then that sucks (about beats audio).
I'm really liking the voice app I have tried a ton of them in the market and this ones is one of the best I've seen. Having the different voice option buttons on the screen after activating the app is nice to have :) just wish it could change the alarm time.
Zemexters
