[ROM][5/23/12][4.0.4][AXI0M] CROSSBREED and PATIENT ZERO
Re: [ROM][V6][4.0.4]DroidTh3ory + AOKP = AXI0M Crossbreed
Anyone seen issues wirth wifi signal? After flashing, i am getting a massive delay on loading websites on wifi? Thinking of reflashng but not sure it iss rom related. worked fine on v3.
my wifi is working without a hitch. what radio are you using? 4.03, 4.04, or a hybrid?
V7 just dropped. Looks like there are 2 versions of 7 now.
Reactions: zero neck
Question about the whole bootloader/radio situation. I'm running the 4.0.4 radios right now, but I flashed the radios only (not the bootloader). So if I flash the GetReady file, re-installing the radios and updating the bootloader, what happens if I decide later to go back to something like codename? Could I just flash the latest codename over this ROM (even though I'm running a newer bootlaoder), or would I need to revert back to my current bootlaoder?
Would restoring a nandroid backup get me back to my present bootloader?
I have a feeling that I wont want to go back to anything once I flash AXIOM, I'm really just trying to get myself a bootloader 101 lesson.
Thanks.
Thanks.
Nandroid does not backup bootloaders, radios, etc. You can run the 4.0.4 radio and bootloaders on 4.0.3 ROMS just fine. You would not have to convert back unless you really wanted to. I have been running 4.0.4 radios/bootloaders for quite awhile on 4.0.3 ROMS. If you did decide to convert back you would have to find and flash the radios/bootloader seperately. ROM's and radios/bootloaders are independent of one another in most cases.
Reactions: greydarrah
Dl'ing now. chose STD version (standard?) over the Sho (more features under the hood) bc i dont like the UI tweak aesthetics.
Also the STD has Franco kernel.
Hey guys, I was on v5 went to v6 and now v7 without data wipes and no issues. I know it's not recommended but did the dirty installs just to see if it worked and to avoid the slightly painful setting up. It's nice to upgrade and everything is all set up.
Sent from my Th3orized GN
Good to know. Will update ASAP.
With the daily (sometimes twice) updates the setting up gets kinda annoying. And you know we NEED to install every single one that comes out. :-P
Re: [ROM][V7 - STD/SHO][4.0.4]DroidTh3ory + AOKP = AXI0M Crossbre
I may do a clean install just because I am hopelessly paranoid. Flashing SHO as soon as it's done!
Also, does anyone reflash Get Ready? I haven't, but I can see why people do so out of habit.
Amen! Nice sig btw; I was thinking of something like "Sent from my th3oretical Galaxy Nexus"
I thought SHO was already finished. I just flashed V7 SHO a few minutes ago.
Done = downloading on my end lol.
I've flashed it set it all up. Looking good.
I never have flashed it. I have been on the 4.0.4 radios/bootloader for quite some time so I don't even bother.
Hey dmmarck, no CM9 or what? :D
Also, V7 already? I just flashed V6 the other night. LOLz
off8485
