[ROM][5/23/12][4.0.4][AXI0M] CROSSBREED and PATIENT ZERO
Re: [ROM][4/4/12][4.0.4][AXI0M]Crossbreed/DRIVEN/PATIENT ZERO
Ok where'd the file go? The download link for the ROM comes up Not Found, the requested URL blahblahbalh.zip was not found on this server.
Was it pulled? Let me double check the first post.
Edit: the URL looks correct. I can't check to see if it'd DL b/c I'm at work, but I can see if it matches with the droidHive link.
Ahh, it was a relief coming over here and getting away from the wakelock epidemic at the Hive. Everyone has their panties all twisted, and then there's the other one who posted the same question about DT's script wiping the SD Card in two different threads, and then insisted that it did wipe his card after everyone assured him it wouldn't.
Grrr!
Grrr!
Lmao I'm at the point where I know I need to get up and walk away from the keyboard before I start crackin skulls at the hive.... haha
Or as DT once told me, run across the street and kick the neighbor's dog, come back, feel better :)
I tried screaming at the screen, but it wasn't doing much to make me feel better. :D
wow that sounds awful. and let me guess ... no one experiencing the problems has read the thread to either have advanced warning or learn the fix ...
I didn't know there was a fix...
What happened to the file?
yeah I can't find the updated files anywhere
Just a second...
...They're on the front page? I posted the links as hyperlinked text. Is that too confusing? I can certainly change it back, I just wanted to clean it up a bit!
I think we are both talking about the Monolith B2 link. it is dead.
Ok let me look at that one. I know CB has basically been abandoned, so he might have pulled it just to pull it for space.
if CB is abandoned which one would you recommend updating to?
If you want features--Patient Zero.
If you want a "base" rom--Driven.
Up to your personal wants/needs/etc. I haven't tried driven or V18 yet, FWIW.
has anyone put beats audio on patientzero? if so is it just the normal way of flashing something and are there any problems with it? I just flashed v18 and francos nightly 121!! loving it so far
It is integrated into phase 2 iirc
is there anyway to change the default blue color and the navigation soft key icons?
Trying going into Rom Control. If that doesn't work, then I have no idea.
Thoughts anyone?
Thoughts anyone?
Figure out how to use metamorph to make them whatever you want... I don't mean that in a nasty way, I don't know how to use it well enough to help. But if you have some time scroll through the theme section at rootzwiki, you'll find some threads with many soft key options you can use on any rom, you just need to read and do a little work with metamorph I believe. From what I've read its really not hard, and tinkering with stuff can be fun :)
Sent from my Galaxy Nexus using Tapatalk 2 Beta-5
I prefer ZipThemer ;)
Reactions: 2defmouze
jades
