[ROM] ACE ROM v2.0 (No Further EC05 Development)
Would you like to see the CIQ Removal in the next release of ACE?
  • Total voters
  • Poll closed .
v1.7 is first rom i ever flashed, had np and man this thing smokes now, thx for your work!
Hey Paul,
I just tried the new ACE v1.7 and love it. It is very fast. Everything works on my Epic. I did not notice any problem.
I do not even miss TER V1.5. Thank you Paul.
GO Paul !!!!!
Thanks for the fast response paul, think i figured out my prob, I was using clockwork 3.0.0.5, told you i was new lol, running great for me now, great job on this
Love the New update Paul! Crazy!!! :D battery consumtion isn't that much either even when using 200mhz-1200mhz on it.
Phenomenal work! same goes for the theme! :D excelent!
Hi paul ... I have been able to flash the roms with no problem and as with everyone else here, the rom runs greate... I have been however having 1 issue with my text... There are times when I have flashed the zips and my text doesn't work properly... I can receive text but it stays on a sending loop and never sends it ... After zipping the rom and phone reboots I have to reboot again (using the 3 buttons) then it sends them no problem... Nothing major but annoying. Thanks
Okay, upgraded to ACE 1.7 from Beta, and now my home key has stopped working. Am I missing something?
No changes were made to anything effecting the home key.
Did you wipe 3x before updating to the latest version?
If all else fails wipe and reflash again.
Reactions: takeadare
I rooted my phone last night and flashed this ROM. Loving it so far. I noticed when I use my Tiny Flashlight or Words with Friends app, I get a pop up with a huge link. I am sorry I do not have a screenshot at this time.
But I used the apps initially after rooting and this did not occur. Only once the ROM was flashed, this started happening.
EDIT:Tiny Flashlight...that's what she said :p
i think i may give it a try tomorrow. i have never flash a rom before so hopefully i dont f-up my phone
You will be okay.. Just follow the link on the first post to get CWM3.0.0.6 installed and everything will be fine..
I think this is related to the baked in host file for the ad blocking. Try installing "Ad Free" from the Market and select "Revert". Then reboot and try your Words with Friends and Tinnie Flashlight and see if that works..
I just flashed this rom, wow!! Just one question for now. Is there a way to remap the keyboard so the emoticon button is mapped to the @ sign. I probably is just missing something, but my keyboard is still popping up the emoticon selection screen.
Did you flash the included remapping file on the "sdcard/ACE ROM extras/" to get what you want?
Note: I have not used these remappings yet, but Ragnarokx who created them did run/test all of them.
Reactions: mlpomer
@Paul: This is the same problem i posted earlier with the link and you are right reverting AdFree solves the problem.
Great ROM its fast and battery life is great!!!! I actualy like my phone now it works great with the 200 -1200 settings on SetCPU.
THANKS!!!!!
paul - does it matter if i use the root/cwm all in one method or the root then cwm method to get my phone ready to flash a rom?
the all in one method seems easier (fewer steps)
Reactions: Kikoshi
heritagevine04
