[ROM] ACE ROM v2.0 (No Further EC05 Development)
Would you like to see the CIQ Removal in the next release of ACE?
  • Total voters
  • Poll closed .
Just checked it out on my device and it seems to be working fine. Asked it to call my daughters phone 3 times in a row, it recognized the command and prompted me on screen to "Call Brooke on mobile".
Ok i will try and figure out whats going on... thanks for the help... maybe some one could direct me to the voice dial apk so i can try to reinstall it i would hate to have to reload the entire rom again takes to long to set up :(
I think it works if you're just using voice dial on the phone itself, but fails if you try to use bluetooth voice dialing.
Your right i tried it on the phone and it works but not on the blue tooth :( i use the feature a lot so i miss it lol
you have something wrong with you sd card or the download re-download the file then back up all your data on the sdcard format it then restore the data and try again... should work....
i cant not get this to install for some reason... I was running truly epic before and im complaint with requirments but get an installtion error.
even when i wipe and clear and do all that before. I even re-downloaded the romf rom a different mirror and copied it on to the card with a different name but still get the same error.
this is what happens on screen :
FORMATTING SYSTEM...
unpacking system files...
Placing ACE ROM extras on sdcard....
flushing delvik cache...
creating symlinks and permissions...
uopdating your modem...
script aborted (no error message) e:error in /sdcard/ace rom 1.7.zip
(status 7)
installation aborted.
CAN ANYBODY HELP ME WITH THIS AT ALL?? i have never had a ROM fail like this. thanks!
Hey just wanted to point out that the EXT4 is whats breaking blue tooth this is at the very top 2nd post...
Part 2 - converts your RFS filesystem to EXT4 (Note: as of 2/25 at 11:23am, EXT4 kernel breaks bluetooth functionality. Until we get an updated kernel, if you need bluetooth, stay on RFS)
Paul tries to make sure that new releases arent forcing us all to flash every 5 minutes, so keep that in mind :) You might TRY flashing the Twilight kernel while keeping ACE as the ROM.. On Syndicate ROM bluetooth dialing works, but they dont say whether its the ROM or the kernel that fixes it specifically.
Keep in mind- that ROM has WAY more bugs than ACE, including one that locks the phone if you try to charge it while its off. Id recommend ACE, but perhaps swap the kernel and see if that helps? I just reflashed over to my Syndicate copy to check, and bluetooth dialing works for me...
Paul- i know youve got a million things to do (in life and on this ROM), but if the bluetooth dialing function is important, you might check Syndicate and find out how they fixed it. I for one dont use it, so just a friendly suggestion :)
**EDIT** Clarification: ACE ROM V1.7 uses Genocide 0.3a as its kernel. Syndicate ROM Frozen uses Twilight Zone as its kernel. I merely suggested trying Twilight Zone under ACE to see how it performs in terms of bluetooth dialing. You can find Syndicate over at the XDA-developers forums :)
Reactions: gitit20
I would say its probably kernel related. Kernels are the key to everything, so it would be worth a shot to flash the Twilight Zone kernel while running ACE and see what effects that has.
The link to the Twilight Zone kernel will be in this section.
[Index] Froyo EB13 ROM's, Kernels, Themes, & Other Mods [Updated 3/4]
Reactions: gitit20
just flashed it and so far so good. looks amazing. i dont ever want to go back
thank you paul!
I am and I will Paul. I am looking foward to seeing how long of a battery life I can get. If you release a new version, will I have to reflash?
Thanks again!
=( aww still does not work.
I copied off my card to the computer, and formatted the card. then copied all my stuff back to the card and re-downloaded the install from another different mirror link and still get the same error .... =(
i guess shell just have to stick to Truly Epic ROM... =(
Try to one way Odin to the EB13-CWM3 pre-rooted, then flash ACE, thats what i did. :)
i saw the reply to your past post, what type of SDcard are you using? and is it the original that came with the phone?
i did that too and it took zero effort. getting to rooted with cwm3 took only a few minutes. flashing ace only took a few more minutes after i charged my phone.
Interesting its aborting at the modem install... I would do as suggested and use Odin to updated...
Froyo EB13 Pre-Rooted, Deodexed, with Clockwork - RFS & EXT4
Grab the EXT4 version.. Sounds like you could have an issue for some reason your modem doesn't want to update since its aborting at the modem update part of the install script.
Its the stock 16GB Samsung MSD card that came with the phone. I dont think there is anything wrong with the actual card. It has never been taken out of the phone until today to look at it, and i even formatted it on the PC and got no errors.
I will try later. Problem is its one of the other phones on my account { EVO for me } . And I have limited downtime available with it. So its tricky. But next time I get some time to have the phone off the network I will give it a try.
thanks for the help guys, everyone is always there for each other.
Thanks Paul :) So basically if i flash this new Kernel my phone will be the same? what differences will i notice? I will try this but before i do i would like to know if can just flash yours back in correct?
On other notes its perfect sept bt my battery life kicks but... Its fast as hell... Only changes i have made was the launcher everything else i left as is because it simply works 3 of my friends at work were like WOW and had me flash it to there epics as well...
One other question how can i change the purple top bar haha...
Thanks Royce
I will try and get changed theme adjustment so those of you not fond of the half black and purple status bar can have a solid black bar. Look for it on Sunday early afternoon I should have something up, check the 2nd post.
Reactions: gitit20
You are awesome :) Thanks :D
Thanks man :P all my coworkers were giving me crap about that i am a KSU fan but they are KU and hate purple (because we kicked the buts) lol your the man you really should put up a donation link...
Black Theme status bar/notification bar theme change available.
See #2 post.
tarntime
