[ROM][ACS][STOCK] "Leaky Gingerbread" ED12 :: RFS ONLY :: Deodexed/Prerooted :: 4/27
Status
Not open for further replies.
I have found the build to be very solid, and I would keep it on the phone if it wasnt for the Battery Temp message that constantly comes up. Once the message comes up my screen stays on, so it is always on whether it is charging or not
Everything seems fine other than this. I didn't even have issues with GPS lock. I'm going to continue using the GB for now, but when I get home tonight I might flash back over to EC05. The battery temp message comes up and wont go away, and it's difficult to charge the phone. Unless there's some way to suppress the message I don't think I can use this ROM. I appreciate ACS for giving us the opportunity to run GB before primetime. It's a shame this battery temp message is as predominant as it is. Anyways, Thanks again ACS!
I found it to work good. I was not able to get the GPS to work which is a deal breaker. The Bluetooth works fine which is a plus for me. The game changer was that I could not get the SPB 3D shell to work. I guess I will have to wait a little longer. Overall it was very stable, and quick which gives me high hopes.
I will not use it. When I use Roam Control I do not get any data from the other provider ( maybe Verizon ). On the other hand, I get excellent data and good coverage when I use SRF 1.1.0.
Did you attempt any of the posted fixes?
I did, but since I was at work at the time, I might of cut a couple of corners. I will try again this weekend. If I am able to get the GPS to work, this will be a keeper.
I want to share my experience with this ROM, with the people who are still on the edge about it. First off, I am using it the ec05 modem, no overclocking. The rom is very solid, gps work fine, but you have to remember that all official epic roms come with network assistance turned off. Turn it on and it works like a charm. flash works much better than on 2.2, for example watching jon stweart is very smooth and there isn't sound delay. I haven't tested 4G, so I can't speak about it. The most annoying issue I have is the battery charging indicator, I found out a little solution, plug in the phone to a charger and it goes away. Not perfect by any means, but it works. I haven't run into an app that isn't working. Another main issue is that voodoo doesn't work with this kernel, and the sound during a phone call through the stereo jack is ultra low. Much lower than anything you've experienced so far. The LED notification doesn't work. Visual voicemail doesn't work either, that might be due to the incorrect modem though. Battery charging speed seems faster than usual, significantly faster. Otherwise it I love, and if you have a charger at home and at work, this ROM is perfect as a daily driver. Hope I helped.
Also if you download the new google talk with video chat, yep it works too :-)
Tried again. This time I made sure to get a GPS Lock prior to installation. I went from rooted stock EC05 to ED12. Once installed the GPS worked perfectly. I even went for a test drive to also test the Bluetooth, and both worked great. I still get FC's on the SPB 3D Shell, but I guess that will be fixed later. Now to see what king to battery life I get.
@k0nane,
Since you leaked out this build of Gingerbread any chance your going to be leaking out the next build that has been rumored already? Better yet do you already have your hands on it and have been testing it out? LOL...
@k0nane,
Lol I was thinking the same thing.
these arent the roms you are looking for :P
Used your powers to defeat CIQ, you have? Much improved battery life, there is?
Sent by a little green robot
Not nice to tease Shabby... I'm trying to wait patiently but its hard to do after reading all the goods about the new leak over at XDA.
To bad I'm not lucky enough to be in the circle of lucky ones running this leak already... I'm surprised qbking77 doesn't have a HOW TO video up on it to help further tease the masses.... LOL..
Status
Master zx
