ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Are you using any of the 2sd scripts? Those are not compatible. If you're not, I don't know what the issue could be.
Yeah, link2sd. Probably the problem, thanks
[edit] OK, working fine now. Re-flashed and re-installed all apps except link2sd, working fine.
[/lurk]
He meant that 2sd scripts are incompatible with alpha8.
I ran AOKP alpha8 for a week and it was nice. Would have kept using it, but it was a bit too unstable. I didn't have much problem with wifi or 3g though. Will flash alpha9 once it becomes available.
[lurk]
Any reason why my home button won't work? I'm a noob when I comes to Cm9 :p
OK, got AOKP v8 working pretty well. Can someone tell me how to change the boot animation? I noticed that I can not turn off the boot animation in the ROM Settings (turns right back on) so I thought I could at least have a nicer one than comes with it.
Mms is working for me ;) finally this rom works thanks tdm just need a working camera ill be making a donation as soon as it hits stable
ok i installed aokp on my phone an for sum reason i cant go back to my previous version it says MD5 mismatch on every back up i have, no i didnt delete anything or move anything at all i need help!!!!!!:(:'(:-\:confused:
just go download the custom rom you had before and flash it. I assume you all ur apps backed up and if not, sucks to be you.
I had this problem once. But after another try, it worked. Try again. Or a couple times. Worst it can do is well, not work again.
Sent from your mom's phone.
@tdm could this please be added to the OP! It would make it much easier, when someone flashes aopk, and lose root!!
Also the ICS gapps for the play store to work. Flashed rom, gapps, superuser, then rebooted and everything worked fine for me. :-)
Sent from my LG-VM670 using Xparent Purple Tapatalk 2
Yes I'll be releasing alpha9 sometime this week. It will have an updated AOKP with the Superuser package this time. I will test the 3G related properties to see if they make a difference. If they don't negatively impact anything I'll put them in for testing.
Status
maryhurst515
