ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Ok I just began using link2sd and I managed to get my apps onto my ext2 partition ;-) I have a question concerning rom flashing.....I would like to know basically if the flashing process is altered at all having my apps on my ext partition. Would I need to change anything? Thanks for any feedback
Hey Mr.Jerry ;-) I'm just curious. Is there anyway to match the color of my time bar and status icons to match in color lol ik ik lame question. But if there is a tweak I'm missing or something let me know. If not call it a request if ya get bored. :-D
Lol there is ics cm9 reloaded. Its on xda google it and u can really customize the status bar and notification drawer and also the icon colors.
coming from someone who has no experience coding android...take this with a grain of salt.
we had luck on the S with data when this line was enabled in the build.prop. i dont know if it will help you guys, but its worth a shot.
Code:
#ro.telephony.ril.v3=signalstrength,skipbrokendatacall,facilitylock,datacall,icccardstatus,1
delete the # to make it look like this
Code:
I have no doubt it will do nothing, but, hey, worth a shot maybe?
Here it is for you guys thank eletendre for the fix
Reactions: drm1992
Sorry but wat do you use to edit it. And is it possible to modify it before I flash it?
Sent from my HTC_Flyer_P512_NA using Tapatalk
So there there any alternative to using reloaded theme? I like it but I also like testing :-) tons of logcats.........now if I could just understand them lol
After flash use root explorer and edit. I think its better to modify before flash using 7zip on windows
Ok thanks to both of you. I will give it a shot. I really love ics and want it on my ov hahaha
Reactions: arnold1997
Status
Loki Samhain
