ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
im guessing it has to do with something in the framework. i have no idea how to fix that, ours just started working last release.
Look through the build.prop/framework files for any changes.
This is my Tapatalk 2 signature. Rockin' the app on my Nook Color running ICS 4.0.4, courtesy of Dalingrin, Fattire, and our other beloved XDA weenies (nemith, keyodi, arcee, hacdan, etc.)
I had this problem once. But after another try, it worked. Try again. Or a couple times. Worst it can do is well, not work again.
Sent from your mom's phone.
how long did you wait and retried to do this, i did this for an hour straight ans still nothing
Did you happen to change recovery or anything. Not trying to be a downer. After the 2nd, maybe 3rd pushing it. Its not gonna work. Unless you swapped recovery or something like that.
Whats the best recovery to flash this with? And wat steps are recommended?
Sent from my HTC_Flyer_P512_NA using Tapatalk
Any recovery is allright (i personally use touch)
Steps are:
1.Wipe data/ factory reset(in recovery)
2. Format cache, boot, system
3. Wipe dalvik cache
4. Flash rom
5. Reboot
hmm that may be enough to get me back to a7 or if a9 is comming soon ill wait can i see a screenshot of it locked on
Im on gingerbread right now though... but it definetly does lock, but a major reason is wifi but i heard aokp has a fix for it
Wifi works on AOKP...I used it for a day and a half but went back to BACKside cuz I needed my camera for Easter.
Sent from my LG-VM670 using Xparent Purple Tapatalk 2
Status
HandsomeZinck
