ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Anyone try the new 3g fix with jerryscripts old workaround for mms? The apn settings aren't right on alpha 7, but even changing it to what it's supposed to be didn't fix mms. However, the 3g was dropping mid send/recieve. So maybe the combination of the two would fix mms????
Honestly, I'm tired of changing ROMs, or I totally would. Maybe tonight if nobody else has gotten around to trying this. Do you know what page this "MMS fix" is on? I already know about the 3G fix.
The fix that you're looking for is on page 72 but for the sake of convenience, I'll just quote it here.
MMS works just fine for me, I'm running on Alpha 7 though.
You'll need to edit the apns-conf.xml to reflect Virgin Mobile's values 311 490 ;)
For anyone who wants to try:
- use a root capable file manager, and copy the /system/etc/apns-conf.xml file to your PC (it's too large to edit on the phone)
- open it with a good text editor (notepad may work, but I don't ever recommend notepad).
- search for Virgin Mobile US, and change the mmc to 311 and mnc to 490.
- copy it back to your phone,
- clear cache in the MMS app,
- reboot.
Let us know if it works for you. ;)
Reactions: cole2kb
Really? Must have misses that one....so let me get this straight....I've applied the 3g fix.....but there is also an mms fix too damn....so really the biggies r what video (flash) and the viewfinder issue?
you should make a thread about how to do it step by step and heck if it works ill be on quatt so fast
I working on a Camera fix because that is the only thing that is keeping me from releasing a my version of CM9, I am close now that I have found out what was wrong, time to just fix it. My next fix is the youtube fcs
i think TDM should add the 3G fix+ jerrys MMS fix+ your camera fix=close to RC
im giddy just thinking about it
So what is the problem have with mms? Is it that u get that 999999999 msg or just won't download. Because I got a mms but can't dwnload it. So I'm just wondering. Trying to contribute with what I can
Sent from my VM670 using Tapatalk
Status
FahadsTech
