ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Yes. I saw it happen with multiples at once, as well as single downloads 11mb and larger
I mean, just four apps installed.
Also I can't install downloaded apps, and I have 100+ MB free on the internal storage.
Is it safe to flash the rom over it's self? Could this do anything to help?
Reflashing the rom over itself wont hurt anything. Differing opinions as to whether it helps.. some have said yeas, some say no. Just make sure you wipe the dalvik and cache first. When you say downloaded apps are they amazon apps or play also? There are certain apps that the rom itself wont move, so titanium would be good to use. Don't use app2sd or any of those apps though, they will send the apps right back to where they were and not the partition. The phone will take care of sorting it out on its own
Reflashing the rom over itself wont hurt anything. Just make sure you wipe the dalvik and cache first. When you say downloaded apps are they amazon apps or play also? There are certain apps that the rom itself wont move, so titanium would be good to use. Don't use app2sd or any of those apps though, they will send the apps right back to where they were and not the partition. The phone will take care of sorting it out on its own
Play and titanium backups won't install
Did anyone notice the lag on cm9 when u play music n try multi tasking
Run "adb shell df" and paste the output.
after setting a 1gb partition from my (CWM) recovery, then dumping all of my /data/app contents into my /sd-ext/app folder, my DF now looks like this:
a/local/bin:$PATH <
app_89@android:/ $ su
app_89@android:/ # df
Filesystem Size Used Free Blksize
/dev 209M 32K 209M 4096
/mnt/asec 209M 0K 209M 4096
/mnt/obb 209M 0K 209M 4096
/system 164M 151M 12M 4096
/data 178M 100M 78M 4096
/cache 110M 1M 108M 4096
/sd-ext 915M 119M 795M 1024
/data/dalvik-cache 915M 119M 795M 1024
/data/app 915M 119M 795M 1024
/mnt/sdcard 28G 109M 28G 16384
/mnt/secure/asec 28G 109M 28G 16384
/mnt/asec/com.jrummy.root.browserfree-1 4M 2M 1M 4096
/mnt/asec/com.quoord.tapatalkacf.activity-2 5M 3M 1M 4096
should'nt the dalvik cache be living on my sd-ext partition also? do i need to move it myself?
Force close issue not fixed. Haven't noticed any real difference. CM9.
I love this rom. I know I've only had it for... a day, but it's been awesome. I've gotten my device clocked at 122/806 on SmartassV2. Which governor seems to have the best returns for battery life without making my phone feel like an Intercept?
running an sd-ext partition seems to have stabilized the aokp build, i've only been running it for the last hour but so far so good.
for those of you experiencing random fc's and reboots, try running the "performance" governor...it keeps your cpu pegged at whatever you specify as the max setting...alot of these apps dont like having the clock speed throttled up and down on them....
hello i need some help with a very minor issue. im running aokp 10 pre 3 and idk if im just over looking something but i cant delete any contacts?
Will doing that have a negative effect on battery life
I'm on cm9 now and for me to delete contacts, I go into the people app and click the contacts name. then press menu and there's the delete option. if that doesn't work for you, you could always try logging into google contacts on your computer and deleting one from there.
Reactions: purpulehaze
a/local/bin:$PATH <
It is. Note /data/dalvik-cache is a mount point.
lol i overlooked that just clicked the name and there was the delete option thanx man :)
Status
devon9
