ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Exactly. But after i installed nightly that got fixed lol even though there is an echo but its not a big deal:D
Echo cancellation is a feature in Groove IP, Idk if other phones have that feature or not, but GIP is a pretty nice solution as it works with both WiFi and regular xG service.l
That has been a CM9 / ICS alpha issue since the lockscreen icons were added a week or so back. It appears to not be fixed yet on their side.
Thanks. Sometimes I wonder if I'm doing something wrong. I'm still learning a lot about my phone and just recently got used to the IHO build and now I'm trying to learn the ICS Rom. Thanks so much, I really appreciate it.
I tried. It downloaded as 0Bytes, then 14.6KBs and now 13MBs. :confused:
You have to reinstall beta pre1 then fetch and install the nightly, if you get the right zip it'll be around 73 mb. Do it all with romkeeper, note; you may have to reinstall rk like i did.
This must be your first time with an ICS rom. Chrome beta is for ARMv7 or above. The V and S are ARMv6.
Chrome does not work on these phones. And its like 55 mb once installed anyway.
Sent from my LG-LS670 using Android Central Forums
Ah, thanks. I knew I was missing something. I've been trying to decide between a Galaxy Tab 2 and the likely Asus/Google tablet upcoming, so I've been soaking in threads discussing whether driver support on the Tab was sufficient to let Chrome run. My mistake.
Been using Nightly for about 2 hours. I have a bad battery drain. Lost 40% in 1 hour, only downloaded 2 apps, Terminal, and Tapatalk.
That's way excessive. We have a deep sleep issue but you should still get at least 12 to 18 hours out of a charge.
Did you use RomKeeper to install? When I used RomKeeper to upgrade to last night's nightly from AOKP alpha10, I had no end of troubles, but after a full manual wipe, the nightly seems to work rather well.
It seems obvious, now, that using RomKeeper to upgrade from AOKP to CM9 was asking for trouble, but I wanted to try it out.
For any of you who wish to take a panoramic photo, there is an app called 360 on PlayStore that works fine on this build. Doesn't fix the native camera, which should do the same thing; but it does provide the function rather nicely.
Status
dnszola
