ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
I installed cm9 nightly without the beta and works just fine
I had beta 1 and updated the nightly on top of it, it froze up, apps fcd and rebooted continuiously so i went back did a full system wipe and flashed the nightly by itself . No more freezes, fcs, or reboots now. You're right it can be flashed by itself, And besides the clock lag its pretty sweet
But I thought he said that he was on alpha and flashed the nightly, skipping the beta1pre1 altogether? That's what's confusing me. Well, I guess it doesn't matter as long as it works.
Guys. You cannot flash the delta file, it's just a patch that applies to b1p1 to make a new rom. Once romkeeper creates that new rom, it is a full fledged rom and can be flashed no matter what you are currently running.
Reactions: Revenant Ghost
I also installed straight from the nightly. Maybe TDM set up RomKeeper to download a delta file if you're running beta1pre1?
In any case, I'm with you on the "as long as it works" bit :)
Thanks for clearing that up. I don't want to be accused of giving misinformation.
:D:D:thumbup::D:thumbup: Yes finally rk worked for me WWOOOO HOOO keyboard fixed, mic good to go , BT works with music not with calls :( ( but I know that will get fixed ) aside that yo TDM and to thekraven and to all that was involved( just don't know who else might be involved) this is a sick rom thanks for all the hard work. Oh what's a good gov and oc to use?
Reactions: tdm
Anyone else have contacts issues? I downloaded the b1p1 and the nightly installed it and all was good. Untill i looked at my contact list and it was empty with no way to search for my contact file where i saved them. No issues with it at all with alpha 10. Tried syncing my facebook contacts and my usual google account where they are saved and no luck.
If your sync with Google than go into account and sync in settings and make sure your contacts are synced .:cool:
Oh btw TDM just wanted to let ya know I also flashed redbarons2005 amphetamines on top and its good to go. :D
Reactions: tdm
If Romkeeper doesn't work for you, go to settings and take the manifest URL, put it in your browser.
thanks man did that already but no luck.
I had to flash a different gaps than the one recommended in the op for them to show up.
How'd you fix the keyboard?
You'll need to flash Google apps again after flashing the nightly :)
Word that was the next thing I was gonna say :) just trying step by step glad to hear it's good to go now :cool:
Status
Winnie
