ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
:D:D:thumbup::D:thumbup: Yes finally rk worked for me WWOOOO HOOO keyboard fixed, mic good to go , BT works with music not with calls :( ( but I know that will get fixed ) aside that yo TDM and to thekraven and to all that was involved( just don't know who else might be involved) this is a sick rom thanks for all the hard work. Oh what's a good gov and oc to use?
I use conservative and 320/728 for a good battery life.
On a side note; I can't wait for the finished beta 1!
Reactions: inceyet
I've been looking through here trying to find anyone with this problem, but I can't seem to find it. For some reason, the mic stopped working on my phone after going to the nightly build. When placing a call, I can hear the other end but they can't hear me. I'm also having some other problems with calling in/out, but that's all I've had besides the "Package file is invalid" but I've had that problem with every rom, so idk. So far it's amazing! I just flashed Harmonia until tomorrow and I'll try re-flashing in the morning. I like the look of ICS so much better than GB.
btw, i have the old OV without the Hitachi screen
Reactions: tdm
Glad I am not the only one. Everything, at least everything I use regularly, seems to be working with the CM9beta1. Only issue I had with it was the call issue you described. So I am not the only one. I tried a couple of things to try to fix it and gave up and did a nand backup and installed the latest mirage rom which currently is my daily. I was so close with this one. But hey can't complain. I am not a dev and this was never supposed to run on our phones so I am happy just to be able to try ICS out with my OV.:D
It's just weird because originally I had the AOKP alpha, and I had no problems with calling, but I had some stability issues. That was no problem though. I couldn't really say if it was doing it on the CM9 beta because I didn't try calling anyone. I only noticed a few minutes ago actually. I have to say though, the nightly is a whole lot more stable than the alpha was, that's for sure. Great work tdm. :)
oh.. almost forgot. I seem to get an issue where the stock keyboard is a few pixels past the bottom of the screen. i get half a spacebar basically. The rest of the OS is correctly positioned, and once I install Swype it's fine. Again, the AOKP alpha didn't do this. I'd actually rather have the beta though because it runs so much smoother.
And I remembered what the other calling problem was. While I was calling myself to test the mic, I picked up on the OV, and the phone I was calling from kept ringing while the OV said I was in the call. I only heard silence, and when my voicemail picked up the OV ended the call by itself. It's only ever done that once though.
If you have the keyboard and the mic issue, there's a possibility your not running w the nightly patch. When your on the lock screen, does it say virgin mobile at the bottom, or something about roaming being off?
Reactions: ttcole1254
Hey TDM, is it possible you can put the dates on the nightlys/updates? Something like 06.15.12 would make using ROMkeeper less confusing to use :p
Now that I installed the nightly, I noticed that I lost usb debugging.. I get usb connected prompt and mass storage works. Anybody got any suggestions? I tried rebooting, and I tried toggling it on and off a few times but that didn't work.
i've been experiencing reboots, and i think im the only one as well....
do you have any suggestions TDM ?
Thank you in advance.
P.S. I rarely experienced reboots with your AOKP alpha10pre1
I'm getting roaming off.. Now it all makes sense :) I'll try reflashing in the morning, it's 11:30 here XD
Reactions: jto101680
Todays build failed, so you probably cannot get a delta update until Monday, unless tdm wants to work seven days this week. :p
Is anyone else experiencing trouble connecting to wifi w/ nightly? Keep losing connection after authorizing
Otherwise, nightly is excellent! Running w/ the amphetamine patch, and also got juicedefender working again, which is awesome.
Reactions: inceyet
Status
Beboomo
