ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
CM9 is sick TDM & TheKraven and to all who contributed. Thought I'd just share a screen shot btw titanium back worked just great
Reactions: tdm
i've been experiencing reboots, and i think im the only one as well....
do you have any suggestions TDM ?
Thank you in advance.
P.S. I rarely experienced reboots with your AOKP alpha10pre1
No, you're not the only one :-\
You'll need to flash Google apps again after flashing the nightly :)
Interesting. I did not flash Google apps after the nightly, everything seems to be working fine. What version of Gapps did you use with Beta1Pre1 before the nightly? I used gapps-ics-20120429-signed.zip.
Try the smaller gapps. There is a link in the op
Sent from my VM670 using Tapatalk 2
Okay so I just upgraded to beta 1 and camcorder doesn't work although it did in alpha 10??
Anyone explain why??
I was havingcrazy reboots for two days straight then finally figured out why. I had to change the clock speeds and governor. My min max speeds are 480-600 with smartass2 governor. Cm9 beta+nightly running rock solid on my ov since the change
Hey, sorry to bother you guys with pointless questions but I remember reading that there was a certain way to get romkeeper to stop downloading the files at 56.1 kb but I can't remember where... (and I can't use the "search this forum" feature because I'm on Tapatalk And my computer is in the shop... :P It stopped working last night -_-) but thanks guys for the help and sorry for the pointless question. Lol
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
Is anyone else experiencing trouble connecting to wifi w/ nightly? Keep losing connection after authorizing
Otherwise, nightly is excellent! Running w/ the amphetamine patch, and also got juicedefender working again, which is awesome.
No prob with wi fi whatsoever
sent from my icy cold optimus using inverted T.T.2
just installed the nightly and it runs great! Gapps 4-29 full version with blackICE inverted google apps dirty flashed on top of it worked perfectly.
cant remember what my clock speed was, but im back on AOKP now waiting for it to go beta. this is a banner day for the optimus V.
Thanks (again!) TDM
Reactions: tdm
From RomKeeper, download the beta1pre1 rom first. Then download the nightly. You should then see both the beta1pre1 and nightly zip files in your sdcard root directory. You can flash straight to the nightly zip. Keep in mind, you still have to go through whatever steps (clear cache, system, etc.) you usually go through when you change or update your ROM.
Reactions: Ryuk6666
I'm having a different wi-fi problem. My wi-fi isn't reconnecting when my phone wakes up. I have to go into wi-fi settings and click "Scan" in order for it to detect my access point and connect.
Status
DannaOgle83
