ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
OK I finally figured my problem out, hopefully someone else has noticed this but not to big of a deal.
While watching YouTube after installing beta pre 1 and the nightly I noticed my phone wouldn't reboot unless I was watching something on YouTube. I noticed when I watched smaller videos my phone would reboot every three videos on average and when I would watch larger videos like full episodes of criminal minds it would reboot halfway thru.
I can't take a screen shot because the phone freezes up before the reboot but it has been pretty consist ant with the the videos watched.
Are you overclocked? If so take it down a notch or two and see if problem persists
sent from my Nokia 5110
Hey, Hey... Thanks so much.. I just officially deleted the other back ups (except aokp) and am on this..... Well... Kept one gb rom jic .. Thanks so much for all the hard work..
I did get my highest benchmark score ever too.. 2320 I know it throws inaccuracies.... But it's still fun to run.... Guess it's the consistent inconsistencies....
Question. I said it before, and you replied about an update, idk if you were talkimg to me, or theKraven
Did you get 3G to stay locked during wifi and no matter what?
OK, I can't get the delta to install. From romkeeper, it is its like 36k. I downloaded directly now its 14mg, but its not a zip. Its .delta ? What am I doing wrong?
I've tried uninstalling an reinstalling romkeeper but its not making any difference?
I just downloaded romkeeper and installed it on my phone. Tapped on fetch for the nightly build, but the file is only 56.01kb. Is this right? I tried both Wifi and 3G.
Is there another way to get the nightly beta built?
In RomKeeper, on the page for the individual file, there is a line that should read:
status: verified​
If it says anything different, you may need to fetch again.
What many keep missing is that you need to dl the beta1pre1 zip FIRST and KEEP it on your SD card. Then the nightly delta will patch that zip and make a NEW NIGHTLY zip to flash that will be almost the same size as the beta1pre1 zip.
LG-LS670 w thekraven ICS alpha 15 linaro2 & Tapatalk
Reactions: bbrowe and inceyet
Guys. You cannot flash the delta file, it's just a patch that applies to b1p1 to make a new rom. Once romkeeper creates that new rom, it is a full fledged rom and can be flashed no matter what you are currently running.
So, that means you don't have to have the beta1pre1 installed, just downloaded.
Fetch beta1 pre then nightly then it will make the nightly rom for you
sent from my icy cold optimus using inverted T.T.2
Status
2bit developer
