ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Any other fixes for mms besides go SMS ?
To get MMS working change these 3 lines in the build.prop.
ro.cdma.home.operator.numeric=310120 to ro.cdma.home.operator.numeric=311490
gsm.sim.operator.numeric=310120 to gsm.sim.operator.numeric=311490
gsm.operator.numeric=310120 to gsm.operator.numeric=311490
ETA's kill puppies. Sent from a ______ with Tapatalk
Did you reboot after you made the changes.
Yes. Tests confirm. And carefully reading @tdm posts. :)
LG-LS670 w thekraven ICS alpha 15 linaro2 & Tapatalk
Seems not completely true. I'm on mirage and its not even showing the new beta, therefore its not showing the Delta either. I still have the older alphas listed, along with my mirage.
On my SD card I have the beta, a Delta image, and a nightly zip. The Delta is 14mb an nightly is 34k.
I'm not sure what I'm doing wrong, it's driving me nuts
Also I want to add that any of the hdpi/xhdpi themes should work if you chance your LCD density to 140.
Also, for everyone I suggest turning OFF surface dithering as I have seen increased performance in opening things such as the app drawer.
beta1pre2 is up. Fetch via romkeeper, or I'll have the links in the OP shortly.
Changes since Friday's nightly:
* Synced with CM as of today.
* Fixed CDMA props for VM670, VS660. MMS might work.
* hciattach runs as root (hack!) bluetooth calling might work. (thanks thekraven).
* Possible fix for wi-fi hotspot / tethering (thanks thekraven).
* V6 SuperCharger settings (thanks thekraven).
Tried to compile with linaro, ran into issues. Will keep banging on it.
Also, I upgraded phones over the weekend to an LG Marquee. My VM670 is wifi-only now. So I'm relying on testers to provide feedback for non-wifi-only features: SMS, MMS, tethering, etc. I could test BT calling on VoIP but I'm sure that will be well tested. ;)
Talk to Bob. He said he got a linaro build.
Reactions: tdm
This worked like a charm on the nightly. Also I don't know if anyone else had this happen but Facebook app was only showing a white screen and the blue menu.. In developer options I checked force gpu rendering and restarted. I haven't had an issue with it since.
Status
MichaelCrusan
