ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
So, downloading new beta now. Does this then include the Delta as well? Is this all that needs installed? I could never get the other 3 combination to work ..
Using goo.im to download, doesnt look like their is a delta build
Downloaded B1P2 via RK, did the Install thing, worked like a charm again. Excellent work, TDM, you just keep knocking 'em out of the park.
Reactions: tdm
@tdm: I'm running Mirage at the moment, but when I refresh the ROM list on RomKeeper, it still shows CM9 beta1pre1, instead of beta1pre2.
what version of adobe flash player is compatible with this rom 11 says no I am trying to get crackle to work
beta1pre2 is up. Fetch via romkeeper, or I'll have the links in the OP shortly.
Changes since Friday's nightly:
* Synced with CM as of today.
* Fixed CDMA props for VM670, VS660. MMS might work.
* hciattach runs as root (hack!) bluetooth calling might work. (thanks thekraven).
* Possible fix for wi-fi hotspot / tethering (thanks thekraven).
* V6 SuperCharger settings (thanks thekraven).
Tried to compile with linaro, ran into issues. Will keep banging on it.
Also, I upgraded phones over the weekend to an LG Marquee. My VM670 is wifi-only now. So I'm relying on testers to provide feedback for non-wifi-only features: SMS, MMS, tethering, etc. I could test BT calling on VoIP but I'm sure that will be well tested. ;)
did you connect the LG marquee to virgin mobile or sprint?
Hey tdm, I think bob threw a little help your way for compiling with linaro. Check out the building your own rom thread. :)
G-T-R & Quattrimus CM9 Nuff' said.
(Also, sent from my LG-VM670 using Tapatalk 2.)
Reactions: tdm
Has anyone tested bt calling? Would be sweet to release b1 with everything working except camcorder.
Okay, so from beta1pre1 to beta1pre2 should I do a fresh install? Or can I just format system and data and continue on?
Status
rosannejoy555
