[ROM] Android Open Kang Project
where do you set this?
In this screen in francos app
You will need to scroll down a touch to find it
Sent from my Galaxy Nexus by way of Tapatalk
Reactions: zero neck
I've been having a weird issue on b38 with the dialer. I was leaving a voicemail for someone when they called me back before I finished, so I swiped to answer their call while still in the call to their voicemail. Well after that, when I called someone or when someone called me I would get a "in call" screen with no caller Id, just "in call" where the Id would be and an option to patch that phone call in with the another "ghost" line since I didn't have anyone on the other line at those times. The only way to fix it was restarting the phone. Its happened twice to me now, the second time was a completely random occurrence. Considering goin back to b37 if it happens again. Really annoying to not be able to see the caller id.
Today 06:50 AM
tony bag o donuts
Re: [ROM] Android Open Kang Project
I still have hit the end button 2-3 times to end the call....
and the signal drop is bad...have to change from 38 to something else.
My issue is that some phone call are so low I can not hear the other person. I was on the phone heard that caller great hung up , got another call with in seconds, could not hear them for anything. Also on b38.
Xanth
After seeing a picture of that Motorola "Dinara" phone, I'm now curious, is there a way to alter transparency of the navigation bar in AOKP?
You should be able to hide it with a launcher; you can also find a theme that makes it transparent.
I meant the black area that surrounds the Back-Home-Recent Apps set of buttons. Not sure what that's called.
You can alter the transparency in settings rom control status bar general.
Edit: my bad that's just the bar not the pull down
Watch out with transparency in the status power--it can get a bit wonky.
So I recently installed this rom however I'm not quite sure if I have the newest version and was wondering where I could find it
Navigation Bar, this would be nice if it was transparent. It would add some real estate to the screen (like the full screen mod)
Sent from my GneX via Tapatalk
Get the app Goo Manager found in the market (Play Store) that will get you to the latest AOKP build without linking you to another site.
You are a bit out of date. Go to AOKP.co for the latest.
Reactions: Isamu982
I have the same issues, signal drop is not bad for me, but it does happen. Would definitely be a bigger issue without the new radios.
Thanks alot guys and sorry couple more questions.
1. My Verizon is not able to login saying I need the login client however when I try to dl the app from the play store it says my device isn't compatible
2. The scaling settings seem a bit different, does conservative disable one of the cores when the screen is off? Just looking for the one that gives the best battery life
1. You can get the Verizon Login Client here: https://m.box.com/view_shared/6ca25ad7422ace3519a5
2. Try out Wheatley for battery life. I'm finding it to be quite good!
Reactions: Isamu982
Thanks and as far as wheatly is concerned I'm a little confused on how to install it, do I go into recovery and flash it as a update?
It's in the OC/UV settings in Franco's app under scaling governor.
*customized tapatalk signature*
I think the wheatley governor is only available in the nightly release.
makaosant
