[ROM][AOSP][10/31][JB] Bugless Beast VZW Galaxy Nexus
Re: [ROM][JB][AOSP] 4.1.1 Bugless Beast VZW Galaxy Nexus - 7/14/1
I love the Bugless Beast Rom (Jelly Bean 4.1.1) for my Verizon Galaxy Nexus, but how can I keep the radio stable? My 4G radio turns itself on and off during the day about 10-15 times. Will flashing another kernel or radio help? I am using FC04/FC05 now. I am in the Jackson, MS market, which has 4G coverage. Thank you.
You have my problem. I believe it's a hardware issue. I'm on the FC04/FC05 radios. I've flashed other ROMS/kernels/radios and the problem persists. It's not bad enough to make me trade it in for one that could have the exact same problem. I've even gone so far as to turn 4G off and only put it on when I need to download something.
What makes me angry is that I bought a 4G device, but my phone stays on 3G more than 4G when Jackson is a strong 4G coverage area. I love the Galaxy Nexus except for the weak WiFi and cell reception. I hope the next Nexus is better. I like stock too much to switch phones especially since the Galaxy S3 has a locked bootloader.
My GPS is working now. Pretty fast locks too. It must be when I'm at work in downtown Jackson that it doesn't do too well. Thanks for everything. Now maybe Verizon and Samsung will create a radio to give the Nexus excellent reception. :-)
Hey all,
I have a stock VZW Gnex. I plan on unlocking and rooting using Wug's updated tool, and plan on installing the newest Bugless Beast ROM from (ROM - Downloads). My question is - does this include Gapps and a working radio? I can't seem to find that basic info like I do on other ROMS.... Thanks!
Hey all,
It has both.
Hey all,
Bugless has the gapps included it does not have radios included, if you aren't running 4.04 look in Zero necks radio thread and you will find them, if you are running 4.04 flash Bugs and possibly the JB boot loader and you will be good to go
Reactions: dmmarck
Does anyone know where I can find a step by step for installing this ROM correctly? I’m going to Unlock/Root my phone tonight and I want to make sure I flash it the right way. Thanks!
Right...I'm not sure why I said it had the radios included...I think I was thinking the vzw binaries...my bad!
I'm not sure if its got the JB bootloader included...I don't think so. That's on Pete's site if you need it.
You are correct Pete does have the JB boot loader on his thread on RW and I can confirm it works
Edit: the boot loader is not included in the ROM it is a separate flashable file
Yeah I flashed it back on jelly belly...not really sure of the benefits but having a jb ROM and an ICS boot loader didn't sound too good...
I agree with you on you on that one , It seems a little faster but that could be the placebo effect, other than that I don't really see the difference
Hello, I am kind of stuck on something....I have this ROM, and it is in working order...like everything is setup up...but when i try to make a backup...it tells me that there is No /sdcard/ .android_secure found on external storage, so it skips that and it does the same thing to the cache, No sd-ext found...but still says backup complete.....
I believe that's normal since there "technically" isn't an external SD card on the Gnex.
Reactions: 2defmouze
Perfectly normal. We don't have an external SDcard, but recoveries still check--why? I have no idea. But it's normal.
Re: [ROM][JB][AOSP] 4.1.1 Bugless Beast VZW Galaxy Nexus - 7/19/1
stupid question, but if I wanted to install a "nightly" am I doing the whole factory reset process again? I have to assume no, but I dont know how to install a "Nightly" without this.
hulanpo1
