ARCHIVED: [ROM] aospCMod | AOSP 2.3.3 / CM7 (Gingerbread)
Status
Not open for further replies.
Great, thanks!
Also, I'm not able to change wallpapers. Anyone else having this issue?
Great, thanks!
Well, I don't know why but it suddenly loaded a wallpaper I tried loading about 10 minutes ago. Interesting. Won't let me change it again though. I'm going to try a reboot, then maybe flash again.
Took the plunge. Don't know about battery life yet, as I've only been running it for a couple of hours. Performance wise, Angry Birds has always been my test for snappiness and lag. On AOSP there is virtually ZERO lag, I've never experienced that on this phone before running any other ROM. Running 245/768 Interactive, I haven't tried it on a lower setting yet.
The stock Zeam launcher is nice and has some cool features, but I'm just set on Launcher Pro. I've been using LPP for a long time now and it's set up the way I like so I'm stuck on it.
I've giving this ROM a hard run for a couple of days, but so far it seem like a keeper :cool:
Where can we get more themes? I checked the thread at XDA and didn't see anything mentioned.
Hope you enjoy, I know I do :)
Search the net for CyanogenMod 7 themes. They install as apk's with some even on the market.
Yes! Battery life at last!
Finally, a ROM that can allow my battery to last all day! Actually can go from 8am till midnight without having to bust out the charger(moderate to heavy use). Loaded up flawessly, running ThundeC recovery. Didn't have the button issue till after I decided to give picasticks test kernal a try(just used tr's stock button zip to fix). Left oc settings alone except for switching to interactive. good benchmarks from quadrant and antutu. been a few days now and liking this ROM alot!
Thanks pfer10 and aosp for getting this to us!
Try 122mhz and ondemand. You won't notice a difference.
I can notice a huge difference if I lower to 122. Super laggy coming out of sleep turning screen on for about 10 seconds, then it's fine. But for me, that's too low of a threshold. Might be fine for others, though..
Ok earlier today I tried to wipe cache/dalvik and flashed rom and sprint again, and after the reboot started experiencing a boot loop. Pulled battery, bootloop. Pulled battery went into recovery wiped cache/dalvik flashed rom and sprint again and still bootloop. Pulled battery went into recovery did a complete data wipe, cache and dalvik and flashed the rom, sprint, and then Gapps and rebooted, fine. Loaded up fine and finally this time got the Sprint logo. All of the other times I was getting the Virgin logo.
So, if anyone boots up and it says Virgin, the Virgin-Sprint zip didn't take. I would start from scratch, complete wipe and flash the 3 zips again. Keep doing it until it takes. Otherwise things might not work properly and you may have some issues like I did.
For me, so far so good. Still runs like a scalded dog and kicking strong. I'm off to look for some themes :)
Installed/ing this right now, and thanks everybody for all of your questions but most importantly answers in this thread and others. You all rock, and now I can patiently wait for a gingerbread rom based on LG's official release if that ever happens.
Are you using ondemand?
What recovery are you using?
Nope, it was interactive. But now I'm thinking it's because I had setCPU limiting the screen-off speed to 122-245. Still, though, I just finished updating to VD (finally) so I'm restoring all my apps and settings right now, and I'll see if 122 still acts laggy after I check some things..
Did you "Format System", either directly through Xionia or the flashable zip, depending on which recovery you are using?
I use the CM settings and set low to 122 and 600 with ondemand. No need for setcpu runs great.
Reactions: Hoverbot
Oh yeah! I forgot all about the built in CPU settings. thanks for reminding us :)
I now have mine set to 122Min - 748Max. I'll have a whole day tomorrow on battery to pay with it.
Status
benjifred645
