[rom] AXI0M
Does anyone have a copy of the 2.1 exchange hack they can PM me?
You get used to it.. Takes me like 30 mins to setup everything again but its well worth it.
Sent from my Th3orized Galaxy Nexus
Takes 5 minutes.
My backup and nova launcher. Restore apk and restore home screens. Done. I love it.
Takes 5 minutes.
Lol nice... well I mean it takes a few minutes to get my settings (ringtones, accounts/sync/other random settings) done up the way I like them, then maybe 10 mins restoring the apps I use TiBu for with their data, then another couple minutes to go through installing some other ones manually, then I like to go through all apps and make sure everything is set the way I like it, ensuring things like Light flow and google voice and all my root apps etc have the correct settings and permissions...
So all in all it takes me roughly 30 mins or so, but I do like to take my time, and I am very cautious about restoring data to apps... basically anything besides games and a couple other random tools I use, I like to just take the time to set it up again rather than restore data that might cause issues later on.
Just installed the new update 2.2 and now Google wallet doesn't work. When opening the app it starts to open then says "secure element not responding"? Any thoughts?
Anyone getting random shut offs on 2.2? Twice already today I had to pull my battery to get the phone to turn back on.
Switch kernels?
Switch kernels?
Had the same issue with random reboots and freezing. I switched to imoseyon's 1.2.0 stable kernel which was recommended on rootzwiki by 2defmouze. Been running that kernel all day overclocked to 1.35 with no further issues.
Switch kernels?
I've not had to do a battery pull, but did get a random reboot this evening. I've not tried a different kernel. Have you checked your voltages in setcpu? When I was UV'ed on 2.1 too low I had to do battery pulls. My version of setcpu was also a version or two old, and I think that was causing a problem too.
Where in SetCPU do you adjust the voltage?
Reactions: mikestorm
Under the voltage tab. If you do adjust voltages be sure NOT to check the set on boot box. Some devices don't take undervolting well and checking that box could result in a bootloop if you undervolt too much.
Sent using Tapatalk
Sorry, but it doesn't make a lot of sense to me:
1420 mhz
1400mv current
1400 mv saved
1350 mhz
1300 mv current
1300 mv saved
What does any of it mean and what settings are good/recommended to try?
1420 mhz
1400mv current
1400 mv saved
1350 mhz
1300 mv current
1300 mv saved
Generally, the higher the processor speed, the higher your voltage should be, as more processing power should require more battery power. With undervolting you are attempting to dial back the battery power in order to extend battery life without affecting processor or phone performance. You can click each processor setting and try your own settings if you wish. But, most kernels out right now are not properly set up to take advantage of undervolting yet from what i have read.
Reactions: greydarrah
Is it possible to get this on my GSM Nexus and have my mobile network work?
If your talking about the rom check with the developer to see if it will work with a gsm phone, and yes your gsm phone can work in the states but it would have to be off of tmobile or at&t not verizon.
Yea.. I'm noticing its happening when powering the phone on an off. Has something to do with my profile set for screen off and the governor. On demand and interactive x are giving me a problem. I'm trying just plain interactive for now without a problem. If anything I guess I'll get rid of my screen off profile or just switch kernels.
Anyone off hand have the link to Imos kernels?
I still haven;t had a reboot since installing yesterday. If it helps, I'm running my SetCPU with interactive scaling set to 1350 max and 350 min, and my screen off profile is 350 max and 180 min. I haven't touched the Voltage controls.
Me either..haven't messed with the voltages. I'm using 350/350 for screen off. Using the interactive governor seems to be working. I think it was interactive x giving me the problem.
I loaded 2.2 and the 4.03 radio yesterday. I have not changed anything and all seems fine.
everything is working fine on my phone , only question i have and i havent been able to get an answere from anywhere as of yet is, i cant seem to upload any videos onto facebook. i'm just wondering if its rom related or ics related? i loaded an app from the market to see if i can do it that way and still having the same issue.any thoughts?
tommyjack7895
