[rom] AXI0M
Yea.. I'm noticing its happening when powering the phone on an off. Has something to do with my profile set for screen off and the governor. On demand and interactive x are giving me a problem. I'm trying just plain interactive for now without a problem. If anything I guess I'll get rid of my screen off profile or just switch kernels.
Anyone off hand have the link to Imos kernels?
Don't know if you still need it but link to imoseyon's kernel thread on rootzwiki is below.
I'm running the stable version of 1.2.0. Have been running the interactivex governor with slight undervolting with min/max of 350/1200. Not using a screen-off profile. So far no reboots or SOD today so keeping my fingers crossed.
Apparently, undervolting didn't really work on the prior versions so the crazy low voltages that people were reporting did not reflect the actual voltages being used. If you decide to try adjusting the voltages down, I suggest creating a "safe mode" zip in SetCPU so that if you bootloop you can flash the zip to restore to stock values during boot.
http://rootzwiki.com/index.php?/topic/13092-[kernel]-Leankernel:-Minimalistic-Kernel-(1.2.0,-12/31/11)
Sent using Tapatalk
everything is working fine on my phone , only question i have and i havent been able to get an answere from anywhere as of yet is, i cant seem to upload any videos onto facebook. i'm just wondering if its rom related or ics related? i loaded an app from the market to see if i can do it that way and still having the same issue.any thoughts?
I've seen you posting this everywhere multiple times... the reason no one is responding is probably because they are not experiencing this issue so can't advise, they aren't just ignoring you.
Not trying to be rude about it, lol. If I had to guess it's probably the facebook app that needs to be fixed. You could always make a backup of your phone, flash a different ROM and test to see if it works so you'll know if its a rom issue.
ya thanks i did post it somewhere else and no one answered, usually they are pretty good with some kind of an answer lol. thank you
If it was 720P probably. It took longer than I expected on wifi but then I realized I had recorded in 720P.
So is google wallet working for people on the older kernal, 1.2? I use it quite often so i want to make sure it works before flashing the ROM.
Has anybody else had problems downloading MMS pictures with this ROM? I've heard some people having this issue stock, but I still can't download pictures from text messages. I have the setting checked to automatically download the images, and when I get a picture message I get the "Download" button, but when I click it it does nothing. Any thoughts?
OP has been updated with 2.3 change log and download link, looks like some good fixes. Downloading now and will report back any findings.
I just flashed the straight up 2.3 (no MODs on top of it) and noticed that the Google search bar is back. Just wanted to make sure that's what you guys are seeing as well.
Running 2.3 and with Nova launcher and I don't have the Search bar. Don't remember if it was there before I re-loaded Nova or not, though I think it might have been. I think you had an option in 2.1/2.2 to disable it, just open the App Drawer and hit Menu->Settings, might still be there just switched the default?
Reactions: greydarrah
Well, I don't mind it being there. I actually added the widget back to the top of all my home screens anyway (when on 2.2). I just want to make sure It's SUPPOSED to be back. I don't want to spend the next hour setting everything back up and then discover something went wrong and I need to re-flash.
Anyone else notice the search bar after flashing 2.3?
Yes the search bar is supposed to be there... as noted in the OP. DT re-enabled trebuchet launcher by default because so many people threw a fit about not having that ugly search bar everywhere.
And no you aren't supposed to see it on Nova launcher if you didn't enable it on Nova specifically, you have the option to under Nova's settings.
Quick question, I downloaded axiom 2.3 to my comp, is there anyway to transfer it to my GN? Every time I try it says device has stopped working or something like that. Anyone know what to do?
yantri
