[rom] AXI0M
The search bar was there for me to you can remove by going in the app drawer and hitting the settings/menu button on the top right.
Reactions: greydarrah
Quick question, I downloaded axiom 2.3 to my comp, is there anyway to transfer it to my GN? Every time I try it says device has stopped working or something like that. Anyone know what to do?
How are you trying? If connected by USB, then when you open your Nexus directory you're looking at the sd card folder, just drag and drop it there. Also it might help if you were specific about what computer/OS you are using..
Sorry about that, I'm using windows 7 and I have my GN connected as a media device with usb debugging on. I tried to drag axiom 2.3 zip file into the root of my sd card of my GN and it is saying
Cannot copy item ;The device has either stopped responding or is disconnected.
It should transfer over like any other file. Try rebooting the pc and the phone. If you still have issues, just download directly from your phone. I couldn't get the source link to download to my phone, but the mirror link downloaded just fine.
I noticed that none of my apps started auto downloading after the flash. Then I rebooted and they all started coming across. My want to give that a try before you go through the process of a manual download. TBU would work as well, but I always like to get fresh market installs if it's automated.
Try checking out wifi file explorer from the market. I believe it works on any comp using a web browser. It is fast and painless way to transfer files to and from your phone via wifi. No cable needed.
Its free but the paid version has batch transfer and more features. This is an invaluable app for me.
There are a few of these apps. Are you using the one from SMARTERDROID?
Thanks for all the help, I restarted my computer and phone and it still wasn't working. Went ahead and just downloaded it on my phone. The first time it failed but it worked the second time.
This app is made by doublou (sp?) They have the most favorable reviews of the others.
Once you use this it just rox. I never use a cable and getting started and using it is way faster than fumbling with the cable. Plus the transfer speed is just as good as a cable imo.
WOW!!! That is the coolest app ever made! I bought the PRO version. This thing is going to change my life (albeit in a small, but thoroughly enjoyable way). It is so easy to use and now I am cable free. Thanks a million for the tip!
Sorry, I'm confused (too much champagne). Is this an app for the computer to transfer files without a cable? Does it work on the Mac? Thanks...hic...
I have the exact same problem, but if I put the file in a folder and move the whole folder, no problems. *shrug*
I think something is wrong with the 2.3 file. When I check the MD5 I get this:
12492367d8e327ece1258a27957f9b1f
File name is AXI0M_V2.3_LKEXP_MAC_BUILD_SIGNED_1
Can someone confirm this please?
yes, redownload. should be MD5:7d809960ca1f46adfc8bf15dacf9622d
Wifi Explorer Pro is a great app. I snagged it for free when it was the Amazon app of the day. What the app allows you to do is transfer files between your phone and a computer when they are both connected to the same wifi network. You start the app on your phone and use your computer's web browser to connect to your phone. Have not used with a Mac but since it's browser based I expect that it would work.
Very effective and worth paying for.
Sent using Tapatalk
Downloaded it again. Here's the Md5:
c7a07e8e002c3c546d714c68eef98695
Each file has a different Md5. Each file is different in size by a significant amount. Neither one is correct. What gives? Is this happening to anyone else? Should I just ignore it and proceed? I am currently not rooted but was thinking of attempting it this evening.
Do not flash if the MD5 does not match. It means what you downloaded is different from what the dev uploaded. Flashing a bad download can do bad things to your phone so hold off until you get a good download.
Sent using Tapatalk
Reactions: LocationDudeNYC
Sexygirlsse
