[ROM][BETA] Quattrimus ICS (ZVD)
I get it....I saw that post but somewhere else (now I can't find it) I saw where somebody said it was there...thanks though
Sent from my LG-LS670
It was sblood86, but I think he meant the zip nightlies and not the changelogs. They are AWOL
Reactions: jnow2
Anyway to put in a data toggle? We got swagger and torch..lol airplane mode doesn't bring back my sync so I gotta either go through settings and yada yada or reboot to get blue signal bars back. Thank you!!:) if someone knows how to do this and wouldn't mind sharing that'd be awesome.
Get the Dazzle widget from the Play Store.
edit - You can also set it up as a selection in the notifications. Settings, system, notification drawer, widget buttons and widget button order
- via my Kindroid Jelly Fire Bean JB 4.1.1
Reactions: pmoneyprix
I like the thought but I can't see how to do it. I'm running aokp with nova prime, I see options for toggles and stuff in rom control but nothing for adding a widget toggle. Can you dig in a lil further for me please?
those instructions work in cm9 ROM. do not use aokp or rom control. too busy to do research for you on a ROM I dont use, sorry
Sent from my SGH-T679
That's quite alright.. wasn't asking you to hold my hand thru it, or do research on a rom you don't run. Rom control is built into aokp, wouldn't expect you to know that tho...
I've been getting a problem with music skipping with literary every music player . It like gets stuck and repeats a part of the song. This lasts for about one second but it happens frequently. Is there any way to fix this? Also power amp crashes on startup.
I noticed that if I run anything other than on demand or performance I get the occasional skip playing music. Try changing your settings, If that doesn't help wipe and reflash and see if that helps.
Alright couple things I'm having issues with. First, MMS messages won't download. This really sucks cause now I cant get pics from the gf.
Second, Pandora worked perfect the first time I used it. Now every time I open it, it just says loading and never plays.
Lastly, its not a big deal but when I reboot or try to turn the phone on from the battery charging screen while its plugged in it shows the LG logo like its going to boot up then just keeps going right back to the battery charging screen. I have unplug it, boot the phone then plug it back in to get around it.
1) I had issues with this occasionally. I think I got it to work toggling mobile data.
2) Again try toggling data, if that doesn't work, clear cache and dalvik.
3) When you reboot the phone and it goes to the charging screen, hold down the power button until the LG logo comes up, and then release it after the logo has been on the screen for about two seconds, and it should put you through to the Q logo and the AOKP bootanimation.
Reactions: bum_jesus
1) That didn't seem to work. Still just says downloading then goes back to the download button.
2)Toggling data fixed Pandora though! =]
3) I haven't tried this yet will get back to you.
Also don't know if it makes a difference but I'm running CM9
I couldn't get mms either and it wouldn't split long messages. So I gripped gosms and everything works great now. Wireless hotspot didnt work till I got an app wireless tether off xda. Not wifi tether, that ones on the market and didn't work for me. :p
2 Things (running CM9 on LS670)
  1. MMS: Can receive but not send, I understand others are having issues w/ receiving as well?
  2. Headset MIC: Does not appear to work in calls; I hear people but they don't hear me.
I was hoping these were related to beta1 and possibly fixed in the nightlies but that doesn't appear to be the case. I'm not really concerned about not being able to send MMS so long as I continue being able to receive but I would like to be able to use my earbuds, it's part of why I have them in the first place.
Edit: read back, looks like some people are using gosms as a work around... I suppose that's a viable option but I have to at least say I would prefer to use the stock messaging app (preference doesn't always outweigh practicality though so no worries)
I happen to one of the lucky ones whose stock messaging app seems to be working. That said, the catch is at times I won't even RECEIVE messages. I usually have to reboot my phone after a day or so or else I stop receiving messages. I know they're there cause I get them in my Google Voice app and on the computer, but they won't go to my phone. It just started a few weeks ago, so I don't know. I tried updating the SMSC number and all I got was refresh errors and update errors.
It should be the same on CM9. Sorry, I forgot that Quattrimus wasn't just AOKP hahaha.
For MMS, you can try replacing the apk in /system/app with this one here: [APP][ICS] Modded Mms.apk v1.3 - Check OP for features - xda-developers
Then reboot into recovery, wipe cache and reboot. No guarantees this will work, but I know there had been issues in the past with the actual MMS.apk being the problem. Also, this modified version Messaging is much nicer anyway, IMO (:
Same here. Get em in Voice, but not on the phone. Happens every couple days.
heritagevine20
