[ROM][BETA] Quattrimus ICS
just did a clean install of beta 2 + amphetamines + gapps+new voice search. been a minute since ive been on this rom. adding amphetamines and changing the governer to 480/748 w/ savagedzen made a huuuge performance difference. phone is ultra responsive now, i love it!
Which makes the most improvement, amphetamines or savagedzen?
I can make either or both of those changes for the next release.
I would say both are great for increased responsiveness and performance.
Sent from my Optimus V via Tapatalk
Reactions: tdm
amphetamines imo makes the biggest difference. i was using smartassv2 before with 480/600 and not much success with higher clock speeds, a couple people repeatedly recommended savagedzen on here so i tried it out to improve clockspeed, seemed to work a bit better but once i installed amphetamines it really felt like a big difference. this is coming from using clean beta1 for the last month or so and alpha releases as well months prior to beta 2. I also have not had any reboots since increasing the clock speed + governor change and adding amphetamines. considering this is a new clean install i was expecting at least a few reboots but so far not even a hiccup
I am running aokp, how do you force your apps to your sd-ext3 partition? i have an sd-ext partition on my 32gig sdcard and non of my apps are forcing over like they should. How do i make them? And when i look at my internal space it says i have 173mb free when i should have around 4gb because of my sd-ext.
To those of you using Google Now... Have you gotten the voice interaction to work? I haven't had mine speak back to me. nor have i gotten the mic in the search area to function...am i mis-configuring things somehow...? i'd removed Now and reverted back to regular Voice Search but i see some of you like it, so i'd thought i'd give it another shot. At the time i had been using the mic on the keyboard to get voice input into Now (vs mic in search bar) confounded by its settings... how do "you" have it set up?
Thanks Everyone.
I'm still working through how to deal with languages between thunderc and sniper. The thunderc can really only accept English and Spanish or it grows too large. The current quattrimus code simply removed other language files. But the sniper folks have requested other languages, so I need to figure out how to make those coexist.
In the meantime, I've uploaded a CM9 test ROM to see how the multi-rom thing goes. It's built from a new tree on the server, but should be pretty much the same as the old tree (hopefully). This contains the multi-rom stuff, of course, and also the conditional code for the RIL that does baseband magic for thunderc and 3G magic for sniper.
You may notice that it's a bit larger than beta2. About half of the difference is due to the multi-rom files, and half due to the inclusion of FR, IT, and DE dictionaries in LatinIME (because I haven't sorted those out yet).
This is not well tested. Have a backup handy!
quattrimus-thunderc-cm9-beta3pre.zip
Wipe cache and dalvik cache, and your apps should move to the ext partition.
If you have more than ~20 apps, then they're all on your ext.
Ignore the storage space read out, iits a minor bug, sometimes it will say you used 367mb out of 178mb and have 154mb of free space.
Amphetamines is a series of scripts that can be added to the build.prop that increase the speed and performance of your phone.
sent from my Zom-"Bean'(CM10 JellyBean).
Thanks Everyone.
Please refrain from asking such questions when there is a thread dedicated to Google Now.
Google Now will not be fully functional until all of the needed library files are tracked down, and any other necessary files are edited to support ARMv6 devices.
Does it make a difference that i partitioned it before flasking AOKP? And will it tell me if they're forced over to the sd card? or will it keep telling me that they're phone only
And what is with the app in the app menu in the settings call Unicorn Porn?? and why is it that every time i reboot my phone a window pops up that says "Android is Upgrading" "Optimizing application x of x"
alejandro109322
