[ROM][BETA] Quattrimus ICS
I would like that voice button to do something else...I use the home button to open previous apps....and yes I knew about this feature already :cool:
Reactions: droiddekka
@clodfelterac
Did you get that build prop updated I saw that you had needed to make some edits . Wanted to try it out. Thanks:cool:
GTR, AOKP, MiRaGe, CM9, BOBZ ICS, GODZILLA, Harmonia 2.08 killing the game!!!!!!!
im working on it... ive been experimenting with values and variations on on the tweaks... i lost (inadvertently deleted) the prop i had made previously when cleaning up my desktop (workspace)... so i made another one and have been trying to get it all ironed out... a.i. said he was gonna mess with it too, so he may have something in the works... or not... ill post it when i get it done and tested... :-)
Murphys law is kicking my butt on the kernel project. :mad:
Good news, I found the commit that breaks booting.
Bad news, it's a huge merge that changes hundreds of files.
So I'll need to sort that out manually unless I can find the individual commits in the linus tree.
A lesser dev would have given up, but Drew had to go and ask Ricardo Cerquiera about it so now I have to prove it can be done. :p
Thank u for all the hard work.
Sent from my LG-VM670 using Xparent Pink Tapatalk 2
I would've given up when it wouldn't compile... lol. I can not read kernel errors
Dear god... good luck my friend
What can I do about battery drain?..my battery went from full to 46% in less than 2 hours with only bout 20 texts sent..says. screen on is using 74% of my battery...I lock my screen when not in use and have brightness down all the way
Will it work on ics? Probably the dumbest question I've ever asked.
It's not unlikely that it would work; I don't know about Android kernels specifically, but at least with Linux in general, a system that is compatible with one kernel is compatible with kernels of similar versions. It gets tricky with proprietary device drivers, since their code is, well, proprietary (and therefore not available for devs to study or change). Since devices that commonly use proprietary drivers often provide us with graphics and wireless connectivity, and since they (proprietary devices) are likely to be officially compatible with only one kernel (or a small range of kernel versions), it's conceivable that it's more trouble than it's worth. On the other hand, if the kernels don't break anything that those proprietary drivers depend on, and if our hardware is still fully supported in the kernel (not unlikely :)), it is pretty likely that a newer kernel can be used in ICS.
Reactions: sellers86
That's probably the longest "maybe" statement I've read thus far.
And about the 7/14 aokp nightly, I think the SD ext script might be broken, none of my apps load, but when I flash back to 7/13 aokp nightly, all of my apps are there.
Just thought I'd mention that, since no one else has..
sent from my un-dead sammich
The phone will not charge in recovery
and if the phone is off and I plug it in then the phone will turn on by itself.
Also the phone is not recognized by the computer.
Just for others who follow this: These are documented issues in Post #7384.
Can someone confirm that the VM670 phone is able to charge in Recovery mode, e.g. Cannibal Open Touch v1.2? I doubt it myself, but if it does for someone that is a giant clue for troubleshooting.
Something that may help improve battery life is using the SmartassV2 CPU governor. Set your clocks to ???/122. After I had mentioned it in the VS660 thread, a user replied and stated that after using the SmartassV2 governor he had experienced much better battery life and has not had any lag that he had experienced before and that it felt like a different device.
"One thing about the smartass governor is that when the screen is off it will lower the maximum CPU frequency, which on our device I believe will be either 320MHz, or if your minimum CPU frequency is above that, it will use that instead. That could explain how it is helping with battery."
Seeing as how my post was completely ignored, here it is again...
FYI, I have not had a single random reboot on this ROM at all. I have not done anything to my build.prop either.
EDIT: Also, seeing all you people running stuff like 600/480 on InteractiveX (not specific to anybody, just an example) and complaining about battery life and possible random reboots just makes me facedesk.
Your stubbornness is a benefit to us all. :D
@clodfelterac
Looking forward to your new build.prop. I was using yours from the other day. Had no rr's, but my phone kept freezing when typing or clicking on the market. Switched back to the original build.prop, and it's no longer freezing.
you can try this one if youd like... seems ok but ive still noticed a visual artifact here and there... im gonna dl the latest nightly in a bit and ill keep messing with the prop... but theres only so much that it can do... let me know what you find... ;-)
*** DO NOT flash this zip... extract it... the file is inside***
make a nandroid if you dont already have one... extract the file and place it in /system after you rename/whatever the original... boot to recovery>wipe cache/dalvik>reboot
-edited 07172012...
I got 1900, 2320, and 1893 on Antutu Benchmark test. I'm at the number 1 spot in the Optimus V rankings. :)
Aww yeah.
Thanks for all the hard work tdm! Awesome Rom.
btw, what governor do you guys recommend?
Reactions: tdm
jb804490
