[ROM][BETA] Quattrimus ICS
The battery level doesnt update on recoveries, so that makes no difference. Mine never charged from a touch recovery, only xionia. But I have no problems charging on an ics rom
When you say "battery level doesnt update", do you mean "it does not charge" or "the level reported does not update"? My question is whether I could let it sit on recovery (you suggest Xionia but not Touch) and actually charge, and then I can check the battery level by booting up into a ROM?
I'm trying to narrow where things go wrong and if I can also get it to charge in a recovery where you can charge it, I know at least something that works as expected on our phone (just as we know it charges on other ROMs).
The level doesn't update. And for me, charging never worked in a touch recovery. Only xionia and cwm regular. But yes, in theory you should be able to let it sit charging in recovery then boot into a charged rom. I've done it before.
Reactions: henrikb
Yeah. For me, charging in recovery is faster. But with no charger, battery dies in about2 hours while in recovery. o-o
Sent from my Motorola Triumph using Tapatalk 2
Reactions: henrikb
I was thinking about that. Haha. My theories are that it's screen brightness is all the way up and maybe the cpu is on 600 the entire time? Unless recovery is able to control it? I would think that it does. XD Idk much about recoveries, so correct me if I'm wrong
Sent from my A.C.R. Zombified Quattrimized AOKP OV.
@tdm
Is AOKP not compiling correctly? Last nightly was 7/15 on all mirrors.
sent from my un-dead sammich in my hospital bed
Reactions: lerxst_x
@tdm
Yeah, I found the issue. AOKP is using the CM9 version of bootable/recovery, which recently changed to require an update to openssl. But AOKP is using their own fork of external/openssl and apparently hasn't pulled in that change.
I'm changing my build to use CM9 external/openssl.
Don't know why AOKP hasn't fixed it yet, unless they are ignoring ICS and focusing on JB.
ro.product.model=LG-VM670
That is the value already... :confused:
Code:
$ unzip ../quattrimus-VM670-cm9-nightly-20120716.zip system/build.prop; grep model system/build.prop
Archive:  ../quattrimus-VM670-cm9-nightly-20120716.zip
signed by SignApk
  inflating: system/build.prop
Code:
signed by SignApk
i know... that was more in reference to the user who said that his was listed as V670... im guessing he got one of the modified props where i had changed it to =abadassV670... ive never had any issues with the play store with this edit myself, whether on gb or ics... :-)
I have question for those experiencing the clock lag, does the lag affect the alarm? I've been afraid to use it to wake up for work because of the possibility of oversleeping.
Sent from my LG-LS670 using Android Central Forums
Reactions: topdawg661
I thought it did, but I used it as my alarm one night and it rang right on time. Since you wake up early every day, set it five minutes earlier than your normal alarm and test it for a few days to make sure.
On my phone, it does not seem to affect the built in alarm.
Alarm works just fine, however as a note, I use Alarm Clock Plus instead of the one built-in.
Vibration on notifications font work for Me on latest aokp nightly
Somebody edited my post. Number 810. It does not say exactly what it originally said.
Cheezy313Bby
