[ROM][BETA] Quattrimus ICS
Has anyone had any trouble with 3g not reconnecting after losing service
I have same issue. I have a data toggle and go between that and airplane mode to get it to reconnect. Not a major issue, just a slight annoyance at times
Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
replace the original... added directions to post...
I tested put your build.prop, and I do have to say tat it does make things a lot smoother, but at my usual 844/480 savagedzen, it causes freeze ups, and need battery pulls... but without your build.prop, I can run 844/480 savegedzen without issues. And, I'm on AOKP. Just thought I should let you know my issues with it. :p
sent from my un-dead sammich
Reactions: clodfelterac
About to upgrade from Gingerbreak. Should I install the beta or the latest nightly?
Gingerbread*
And I'd recommend using the latest nightly, both CM9 and AOKP are working fairly well, and nightlies get updated every night very early in the AM. You can use goo.I'm manager from the market to download them. Browse/devs/tdm/roms/quattrimus/nightly/vm670. And the zip will be in the goo manager folder on your sdcard.
I was going to test my old Netflix apk (1.2.2) but I can't even open it in ics. It auto closes. So much for that.
Only the latest Netflix app works on ICS, although there's no video, and it buffers every couple seconds.
Ttpod is a good alternative, it has a pretty sweet widget. And it supports music types that aren't MP3. It now costs on the play store. (Mod edit: Please do not discuss how to get paid apps for free.)
I prefer Apollo with the red theme on aokp with afterburner theme. :3
Silly question. Is there any way to take the status bar toggles from aokp (the toggle style) and put it on cm9?
This is the essence of aokp. You would do just as well to put the cm boot animation on aokp and save a lot of work. ;)
Lol I no it sounds stupid n not worth the effort. Only reason I want it for cm9 is because the video quality on YouTube aokp is real choppy and I'm on YouTube a lot but I love the aokp staturbar toggles
Lol tdm I just noticed it was u that replied to my original post n I refuse to undermine your work. Your from is the best :) I think I mite just switch to cm9 for the moment :)
You can flash ics reloaded or whatever and get the same thing.
Sent from my VM670 using Tapatalk
Cheezy313Bby
