[ROM][BETA] Quattrimus ICS
Lol quattrimus is uping the anty xD
115% ROM, 100% ICS, 15% AWESOME. or the other way around xD
sent from my un-dead sammich.
Can you help me ? sometimes the AOKP rom like reboots my phone by it self -.- it gets annoying and i wanna know how i can stop it because its an awesome rom
Try turning down your over clock speeds, and use the savagedzen governor. InteractiveX and performance often cause reboots.
I just wanted to say as I'm not sure if this has been mentioned before but on quattrimus beta 1 my phone will reliably enter deep sleep mode it seems only if airplane mode is turned on. It is not enough to just have data switched off, as that still seems to prevent it from sleeping. just something i noticed :)
You seem to be running outdated software i suggest downloading a nightly.;)
whats the better build?in your opinion?cm9 or aokp?i know last i checked aokp youtube was a slideshow...
I prefer AOKP, the only time I use YouTube, is to listen to music, so the video quality doesn't matter to me. :p
I like the customization that AOKP has to offer.
Reactions: Badboytoast
I really like AOKP but it's too much of a battery drain. I'm not even using it and it loses battery life really fast.
I rarely burn through my battery, it lasts on average, 15-19 hours standard use (texting, music, occasional phone call, some internet browsing, and Facebook) and 6-9 hours heavy usage (screen off for maybe 5 minutes tops every hour).
I'm clocked at 844max/480min on savagedzen governor, 24/7.
And I don't have any other performance or battery saving scripts flashed on top of the ROM.
You can view the thread I made, listing my entire system configuration.
"The Rom comparison thread"
http://forums.androidcentral.com/showthread.php?t=193304 The ROM comparison/set up Thread.
Jayarealways
